When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Knowledgeable
at 2024-07-28 21:08:20
Point:500 Replies:2 POST_ID:829145USER_ID:11978
General Laptop;Miscellaneous Hardware;Embedded Hardware
Are all model Lenovo W530 laptops able to take a maximum of 32 GB RAM?
Is this true of all of the Lenovo W530 laptops or just certain Lenovo W530 laptops?
Expert: duncanb7 replied at 2024-07-29 00:43:33
it is all can be quad core with max 32G memory, four 204-pin SO-DIMM sockets , you can check Lenvono spec
sheet in pdf around the bottom at this site, http://www.lenovo.com/psref/pdf/psref456.pdf
Expert: dbrunton replied at 2024-07-28 23:19:08
Possibly just certain ones such as the quad core ones.
See this thread http://forums.lenovo.com/t5/W-Series-ThinkPad-Laptops/W530-adding-memory/td-p/883101 but I can't vouch for its accuracy.
The whole system is totally configurable from when you choose, see http://shop.lenovo.com/us/en/laptops/thinkpad/w-series/w530/#techspecs but this doesn't state as to whether the 32 Gb covers all processor options.
Page 83 of the User Guide http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/t530_t530i_w530_ug_en.pdf indicates that there are four slots but if a dual core processor is in the machine then two of these are dummy slots and memory can't be used in them so this seems to confirm that only the 32 Gb is usable with the quad core processor and 16 Gb with the dual core processor.
