When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by akdreaming
at 2024-07-28 14:20:32
Point:355 Replies:6 POST_ID:829143USER_ID:12038
Internet File Sharing Software;;Miscellaneous Networking
What is the "GET" command to get more than one file out of the same folder using FTP?
Author: akdreaming replied at 2024-08-22 14:37:47
Thanks. Worked for our needs.
Expert: 5teveo replied at 2024-08-16 07:46:55
355 points EXCELLENT
Use
ftp> mget *.*
mget is command to pull multiple files in FTP script
Does that make sense?
ftp> mget *.*
Author: akdreaming replied at 2024-08-04 14:37:15
I'm told there are about 8-10 files out there, with varied file extensions. So what I want is the command that pulls down every single file in the folder, regardless of file name extension.
Author: akdreaming replied at 2024-08-04 13:58:18
I'm unclear on what the *.ps is for. Are you saying if my filename extension is .doc, then I could simply type "mget *.doc" ?
On a daily basis, our users will go out to this site, connect and need to bring down a couple files. There is typically never more than a couple files in there. This is on Windows. Our issue is that the files are named by date each day and we don't want to have to change the script each day just so we can grab the file by filename. I just want to grab all of them.
Expert: 5teveo replied at 2024-07-28 17:50:39
Try this pattern
To get several files from a remote host:
ftp> mget *.ps
This transfers a copy of each file with the fileneme extension .ps in the current directory on the remote host to the current directory on the local host.
Do you need complete script?
ftp> mget *.ps
Expert: duncanb7 replied at 2024-07-28 14:26:52
You want do it on window or linux ? Please write us more about your
system or setup
system or setup
