When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by bbdesign
at 2024-07-28 09:02:40
Point:500 Replies:9 POST_ID:829138USER_ID:11863
JavaScript;;Hypertext Markup Language (HTML)
I am using a small Javascript tool called rwd.images.js (https://github.com/stowball/rwd.images.js) to responsively load images based on CSS media queries. The markup ends up looking like this:
<img class="rwdimage" data-rwdimage="(max-width:768px){src:url(imglo/ph_home_waterfront_1.jpg);},(min-width:769px){src:url(img/ph_home_waterfront_1.jpg);}" data-category="Waterfront 1" data-link="waterfront-1.htm" alt="Waterfront 1" /> 1:
Since these images are useless in a browser with no Javascript capability, I believe my next best option is to use <"noscript>" to allow them to fallback gracefully (yes?).
This is what I've come up with?
<"img class="rwdimage" data-rwdimage="(max-width:768px){src:url(imglo/ph_home_waterfront_1.jpg);"},(min-width:769px){src:url(img/ph_home_waterfront_1.jpg);"}" data-category="Waterfront 1" data-link="waterfront-1.htm" alt="Waterfront 1" />"<"noscript>"<"img src="imglo/ph_home_waterfront_1.jpg" alt="Waterfront 1" />"<"/noscript>" 1:
I removed the data tags that would also be useless without Javascript. I haven't really tried this kind of thing before, so I'm just looking for advice... is what I'm doing the best approach? Any suggestions on a better way to handle it?
Thanks!
Author: bbdesign replied at 2024-07-28 10:42:38
Thanks for your input!
Expert: duncanb7 replied at 2024-07-28 09:38:06
Dear Author,
I search it from google internet and just only find style change to do noscript besides old one such as at
http://www.w3schools.com/tags/tag_noscript.asp
Is it worth to care about who don't use javascript ? just up to you
Expert: Gary replied at 2024-07-28 09:36:52
Found something from the UK government
https://gds.blog.gov.uk/2013/10/21/how-many-people-are-missing-out-on-javascript-enhancement/
0.2% of people have non js browsers.
Expert: Gary replied at 2024-07-28 09:24:09
I tried to find some stats on non js browsers/js disabled, latest data is from nearly 5 years ago where it stood around 2%, I would be surprised if it is even over 0.5% at this point.
Author: bbdesign replied at 2024-07-28 09:18:06
@duncanb7 - so that would be an example of the CSS workaround that Gary was suggesting, I think. To make it so broken images don't appear on the site.
Expert: Gary replied at 2024-07-28 09:17:11
Aren't there still a lot of people browsing the web on non-smart phones
Maybe they are but should you spend 20% of your time on 0.5% of your visitors.Thats why some many sites no longer support IE8 because the work to time ratio is not worth it just make the site work in IE8
And smartphones are so damn cheap these days anyway
Author: bbdesign replied at 2024-07-28 09:15:49
I keep hearing conflicting things from people about supporting no-JS. Maybe that time has passed and I should just ignore users with no JS, that is always an option. There are always some developers who insist on supporting every possible variation of browser, browser version, JS vs. no-JS, which CSS selectors will work, etc. But I tend to agree, you have to draw the line somewhere.
Aren't there still a lot of people browsing the web on non-smart phones? Maybe things have really changed that much in the past year or two (which would be nice).
Expert: duncanb7 replied at 2024-07-28 09:13:55
You can use css to do it that let you more flexibility, for example code as follows
<html><head> <noscript><style> .jsonly { display: none } </style></noscript></head><body> <p class="jsonly">You are a JavaScript User!</p></body></html> 1:2:3:4:5:6:7:8:9:
Expert: Gary replied at 2024-07-28 09:09:02
Then you would end up with a broken image for the first one.
Though you could add a class to your responsive images, add some CSS in a noscript tag that hides the responsive images
In this day and age using a browser with js disabled pretty much excludes you from using the internet period
Tell people to enable js or use a browser with js
