When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by gwh2
at 2024-07-27 21:07:18
Point:500 Replies:18 POST_ID:829130USER_ID:12023
jQuery;;JavaScript
Hi everyone,
I'm trying to get a jquery based image slider working on the home page of a website I'm working on but the code doesn't seem to be loading for some reason. My page is located at the following url:
http://bc-interiordesign-au21.businesscatalyst.com/
I have the following code positioned at the end of the page:
<script src="/_assets/js/jquery-1.9.1.min.js"></script><script src="/_assets/js/foundation.min.js"></script><script src="/_assets/js/scripts.js"></script><script> $(function(){ $(document).foundation('orbit', { animation: 'fade', slide_number: false, bullets: false }); });</script> 1:2:3:4:5:6:7:8:9:10:11:12:
I wondered if someone could take a look to see what the problem might be?
Really appreciate any help.
Author: gwh2 replied at 2024-08-03 18:50:11
Thanks so much. I added your code and it's working perfectly now. I really appreciate it.
Expert: Gary replied at 2024-08-03 18:07:23
Doesn't seem very HTML5 friendly
We can cheat though, just before your foundation jquery code add the bolded line
$(".slideshow-wrapper > ul").attr("data-orbit","")
animation: 'fade',
bullets: false
animation: 'fade',
bullets: false
Author: gwh2 replied at 2024-08-03 18:02:39
Adobe Business Catalyst
Expert: Gary replied at 2024-08-03 18:00:58
What CMS and version?
Author: gwh2 replied at 2024-08-03 17:58:47
Ok, I added your suggested code and checked the source code in the browser but it was still being stripped out
Expert: Gary replied at 2024-08-03 17:47:14
As a test use this instead - it's valid HTML5 so it shouldn't be removed.
data-orbit=""
data-orbit=""
Author: gwh2 replied at 2024-08-03 17:44:59
Hi, yeah it must the cms that's stripping it out. I'm looking into it and will post back once I know. Thanks
Expert: Gary replied at 2024-08-03 08:04:17
Just did a quick check and the browser does not strip it out.
Are you using a CMS - not clear from your code. It is probably that stripping it out.
Author: gwh2 replied at 2024-07-28 18:35:47
I re-inserted the ul tag but when I checked the source code in the browser it wasn't there so it seems the browser is stripping it out for some reason.
I don't how to get it to work.
Author: gwh2 replied at 2024-07-28 18:28:39
I added the data-orbit back into the ul tag. Also, I realised that the js include file was different but I hesitate to remove it at this point as it may be related to something else on the page. Someone else put this together so I'm trying to work out what they've done.
Appreciate any further help.
Expert: duncanb7 replied at 2024-07-28 12:33:00
Dear Author,
And I see your javascript include file at <script> tag is different from the site I posted in previous post. Please take a look at it if you keep using orbit.
Expert: Gary replied at 2024-07-28 12:30:04
Can you add the data-orbit back in so I can see if there is another issue.
<ul data-orbit>
<ul data-orbit>
Author: gwh2 replied at 2024-07-28 11:47:51
Thanks for all the comments,
Gary, I tried your suggestion but I'm still having no luck. You said to also put data-orbit on the ul tag but for some reason the browser is stripping this out. I tried adding it in as an id and then a class also but neither worked.
Do you have any other suggestions to get this working? I know it's deprecated and not supported but it's still included in Foundation so I'd rather use this.
Appreciate your help.
Expert: Gary replied at 2024-07-28 07:56:53
Your div container for the slideshow needs the class orbit-container added
Your slideshow UL needs data-orbit added to it e.g.
So you end up with
So you end up with
<div class="slideshow-wrapper touch orbit-container" id="hero"><div class="preloader"></div><ul data-orbit> 1:2:3:
Expert: Ray Paseur replied at 2024-07-28 04:04:56
The latest jQuery is available here:
http://code.jquery.com/jquery-latest.min.js
Orbit is circling the drain. "Deprecation Notice: Orbit has been deprecated, meaning that it is no longer supported." Alternative jQuery-based image sliders are listed here:
http://foundation.zurb.com/forum/posts/14504-moving-on-from-developing-orbit
Expert: duncanb7 replied at 2024-07-28 00:41:30
Please take a look tutorial for foundation orbit and its script file including at
http://foundation.zurb.com/docs/components/orbit.html
it seems jquery code should be something like this
$(document).foundation({ orbit: { animation: 'slide', //// other variable here.........................}}); 1:2:3:4:5:6:
Expert: duncanb7 replied at 2024-07-28 00:29:04
On chrome browser click options->tools->developer tools->Console,
YOu can do this similar to other browser but you find where is developer tools tab
On Console screen, check whether all javascript code is no error at all first, it may be just
javascript sytnax issue
Expert: Raghu Mutalikdesai replied at 2024-07-28 00:28:23
I suspect your path for JS is incorrect or you are missing some files. Through Chrome debugger (Developer Tools), I see that _assets/js/jquery.min.map is missing or path is incorrect. Similarly, I got warning for widgets.js.
