When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Richard Morris
at 2024-07-25 21:39:18
Point:500 Replies:8 POST_ID:829114USER_ID:12010
Asynchronous Javascript and XML (AJAX);jQuery;JavaScript
I need a zero written into empty spans if they are empty, else no change required.
Example:
<span id="empty1"></span> // change to <span id="empty1">0</span>
<span id="empty2">1</span> // no change required
Example fiddle:
http://jsfiddle.net/RichardMorris/D5XJ6/
Example:
Example fiddle:
Author: Richard Morris replied at 2024-07-25 23:34:10
Expert: duncanb7 replied at 2024-07-25 23:19:24
I am using older one.
Done
Done
Author: Richard Morris replied at 2024-07-25 23:17:23
1.10.2 is what's on the server and I can't change it to older.
So what works best for 1.10.2 requirements?
Expert: duncanb7 replied at 2024-07-25 23:12:49
Both also works I tested at my server
Expert: duncanb7 replied at 2024-07-25 23:10:34
it works for me at my side,
$('(#empty1,#empty2):empty').text("0");
it might depend on version of jquery
Author: Richard Morris replied at 2024-07-25 23:09:10
Hello Duncan,
Doesn't work in my template but this does:
$('#empty1:empty,#empty2:empty').text("0");
Let me know if this will be okay?
Expert: duncanb7 replied at 2024-07-25 22:28:16
Ignore my previous post
Try this,
it should work
Please read the :empty selector at jquery site
http://api.jquery.com/empty-selector/
Try this,
it should work
Expert: duncanb7 replied at 2024-07-25 22:17:37
$('#empty1,#empty2:empty').text("0");
Try this
Try this
