When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by fparvini
at 2024-07-25 16:40:11
Point:500 Replies:7 POST_ID:829110USER_ID:10
Microsoft Excel Spreadsheet Software;;VB Script
Hi ,
I have an excel sheet file with full of VB codes, need to give it to client, but don't want them to see all my codes.
At the same time, want them to be able to run.
Expert: James Elliott replied at 2024-08-20 22:24:34
Not sure that was deserved.
Expert: James Elliott replied at 2024-07-28 12:27:19
Very true
Expert: Patrick Matthews replied at 2024-07-28 11:05:34
Do note, though, that sharing the workbook is itself inherently dangerous; having multiple people in the file at once creates a huge risk of file corruption. It is only a slight exaggeration to say that there are only two types of shared workbooks: those that are corrupt, and those that soon will be :)
Expert: James Elliott replied at 2024-07-27 11:33:21
Share & protect the workbook is probaly the best of a bad bunce of options. That makes the VB project unviewable, and it's a bit harder to crack.
Rgds
Jell
Rgds
Jell
Expert: ProdOps replied at 2024-07-26 11:48:51
Screen captures showing the steps to lock the VBA code for viewing and editing. Select the Protection tab in the VBAProperties Dialog check box, click the box to prevent viewing and enter a password required to open the project. As Patrick noted above, this can be hacked very easily with tools if someone really wants your code. If the requirement is to prevent your user community from accidentally changing the code, this works very well.
Expert: duncanb7 replied at 2024-07-25 20:25:06
Take a look this for 3 method to secure your VBA
http://www.wikihow.com/Protect-VBA-Code
If method-2 is not safe enough , method-3, using Add-in that saved in other workbook will be
option
option
Expert: Patrick Matthews replied at 2024-07-25 17:16:38
In the VBA Editor you can lock the VBA project with a password. Keep in mind, though, that this password is inherently insecure, and can be cracked very, very easily using readily available, inexpensive hacking tools.
