When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by newbieweb
at 2024-07-25 11:28:07
Point:500 Replies:10 POST_ID:829107USER_ID:11725
Cascading Style Sheets (CSS);Hypertext Markup Language (HTML);Scripting Languages
I need a pop-up 600px X 400 PX
with a opaque gray horizontal shaded bar across the top that takes up 25% of the vertical height of the window. Otherwise, the background should be white and NOT opaque.
Then I need a centered image which is 1/3 the horizontal width of the window and centered. It does not touch the shaded area on top, nor touch the border on the bottom.
On the top region I need a sentence of centered text .
Thanks.
Thanks.
Author: newbieweb replied at 2024-08-02 07:43:05
Author: newbieweb replied at 2024-07-26 08:53:49
i will give that a shot on Monday ;)
Expert: Gary replied at 2024-07-26 08:08:01
Can you create a test page with your code or use jsfiddle.net
Author: newbieweb replied at 2024-07-25 18:29:52
sorry, it's an internal development project...
Expert: Gary replied at 2024-07-25 13:48:09
Do you have a link?
Author: newbieweb replied at 2024-07-25 13:44:57
I had tried that already without success.
Expert: Gary replied at 2024-07-25 12:21:23
166 points AVERAGE
So we are talking modal and not a popup? Make sure this css is after the jquery ui css file
.ui-widget-overlay
opacity:0;
height:25%;
.ui-widget-overlay
opacity:0;
height:25%;
Author: newbieweb replied at 2024-07-25 12:11:08
This is a jquery dialog I am using:
$("#lotShotPhotoImageDownloadDialog").dialog({
width: 800,
height: 600,
resizable: false,
autoOpen: true,
modal: true,
opacity: 0,
dialogClass: "dr-dialog",
position: { my: "left top", at: "left+250 top+250"}
The opacity is working, but I can not get a shaded (slightly opaque) region for the top 25% of the vertical height
.ui-widget-overlay
opacity:0;
width: 800,
height: 600,
resizable: false,
autoOpen: true,
modal: true,
opacity: 0,
.ui-widget-overlay
opacity:0;
Expert: Gary replied at 2024-07-25 11:31:25
167 points AVERAGE
Whats wrong with the jquery dialog?
All that seems possible with it, for example the top shaded area would need this.
.ui-widget-overlay {
height: 25%;
edit.
Oh you mean a real pop up window
height: 25%;
edit.
Expert: duncanb7 replied at 2024-07-25 11:31:03
167 points AVERAGE
To solve your first question first , please take a look at window.opne popup window
at http://www.w3schools.com/jsref/met_win_open.asp
And other questions, Could you write it more in detail ?
