When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Shawn3
at 2024-07-25 09:52:48
Point:500 Replies:8 POST_ID:829106USER_ID:12005
Unix Operating Systems;;
I would like cron to log start and end times for each job run. I know how to do this in DEBIAN but not red hat.
Author: Shawn3 replied at 2024-07-28 09:21:56
I will try that...but thought it was only for debian based distros...
Tried the crondargs, but it throws an error in RHEL. I think that param is for Debian based distros. Thanks though!
Expert: Gerwin Jansen replied at 2024-07-28 08:55:28
You could try setting higher log level for cron in /etc/sysconfig/crond :
CRONDARGS= -L 2
and then restarting cron : sudo service cron restart
My preference is the solution you've chosen so you can easily keep track of all jobs in one place. And the cron log itself is not accessible for users.
CRONDARGS= -L 2
Author: Shawn3 replied at 2024-07-28 07:40:48
This will work, but I'm looking for system level logging for all cron jobs if possible.
Author: Shawn3 replied at 2024-07-28 07:38:13
Thanks Gerwin. I have hundreds of cron jobs. I think this is a great solution, but was hoping there was a system level logging setting that I could enable.
Expert: Gerwin Jansen replied at 2024-07-25 15:24:41
Simplest is to write wrapper commands (or script)
The wrapper logs start date/time with the cron script's name, calls the cron script and logs end date/time.
Easiest if you give every cron script it's own log file name.
For example:
For example:
00 10 * * * echo "`date` Start of cron1" >> /home/user/cronjob1.log ; /home/user/cronjob1 ; echo "`date` End of cron1" >> /home/user/cronjob1.log 1:
Expert: duncanb7 replied at 2024-07-25 11:53:08
Why not make an example to the experts, other experts will come to solve issue
based your example ? otherwise, they don't know what you need
Author: Shawn3 replied at 2024-07-25 11:50:18
Thanks Duncan, but I know how to use cron. I need to know how to get a start and end time for each of the jobs. Currently, cron logs start time and thats it.
Thanks,
Shawn
Thanks,
Shawn
Expert: duncanb7 replied at 2024-07-25 11:07:11
For example,
*/10 * * 5,7,11 * root command1
0 9-18 * * 1-5 root command2
These lines will run command1 every ten minutes during May, July and November, and command2 once an hour during the working day (09:00 to 18:00) Monday to Friday.
