When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Seamus2626
at 2024-07-25 07:39:41
Point:500 Replies:5 POST_ID:829103USER_ID:11690
Microsoft Excel Spreadsheet Software;;Microsoft Access Database
Im trying to line up indentations in my modules, when i highlight the code and attempt to edit using Format>Horizontal Spacing, the option to do so is greyed out
I have attached a screenshot
I have stepped in and out of the code but the problem still remain, has anyone a solution?
Expert: Rey Obrero (Microsoft Access MVP) replied at 2024-07-25 08:13:03
100 points EXCELLENT
you can use the "Indent" and "Outdent" from the Edit menu
Expert: Scott McDaniel (Microsoft Access MVP - EE MVE ) replied at 2024-07-25 08:12:14
If all you're trying to do is indent, you might try Smart Indenter:
http://www.oaltd.co.uk/Indenter/Default.htm
It's free, and I've used it in every version of Access from 2003 - 2013.
If you need more power, you might consider FMS CodeTools:
http://www.fmsinc.com/MicrosoftAccess/VBACodingTools.html
Total Visual Code Tools is very powerful, with tons of features. I use it every day in my Access work and would be very hard pressed to work in Access VBA without it.
Expert: Helen_Feddema replied at 2024-07-25 08:07:34
There is no Format menu in the VB window (if we are talking about Access here). The indentation is determined by the setting in the Options dialog, opened from the Tools menu in the VB window:
It is the same in the Excel VB window.
If your code has irregular indentations, you have to fix them manually. The setting in the Options dialog only applies to future indents.
Expert: Rob Henson replied at 2024-07-25 07:53:44
I believe the Format menu is only for use with Drawn objects such as buttons on User Forms.
Rob H
Rob H
Expert: duncanb7 replied at 2024-07-25 07:43:56
where screenshot ?
