When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-07-25 07:33:53
Point:500 Replies:31 POST_ID:829102USER_ID:11059
Windows 7;Remote Access Software;Miscellaneous Networking
Dear Experts
Today, I try to use RDC on my window 7 and enable it as administrator by
click start->computer->properties->remote connection tab.But In the remote connection tab, I could NOT find the Remote Desktop Tap that is similar problem shown in image in this following link
http://www.sevenforums.com/network-sharing/310095-can-t-find-remote-desktop-conection-windows-7-a.html
Now google search for the issue and find the article at MS
http://technet.microsoft.com/en-us/library/cc782195(WS.10).aspx
And following instrcution, I could NOT find "Enter Network Password" dialog box, why,please advise
So I go run services.msc at command-line, everything is enabled such as
Workstation, Remote Desktop Configuration, Remote Desktop Services, and
Remote Procedure Call(RPC) all are enabled besides Remote Access Auto Connection
Manager and Remote Packet Caputure Protocal v.0(expermental) both are NOT enabled.
My question-1 Any hint why I counld NOT find the Remote Desktop Tag ?
Now my home router is just connected my window 7 computer only , No other computer
is connected to the router. The root cause of my question is I may need to have
both testing computers are connected to router first in order to let the Remote Desktop Tag is enabled, Right ?
Expert: rindi replied at 2024-07-26 08:10:17
Teamviewer isn't the same as Remote Desktop. It works on any OS you can install it on (Including Linux, Android etc.). It also works differently, more like Remote Assistance, which is also included on the home versions of Windows. It uses a gateway service provided by the teamviewer company to connect to remote clients, so that way it is easy to connect to PC's anywhere on the internet, without having to know the remote IP address, or forward ports on routers.
Author: duncanb7 replied at 2024-07-26 07:25:09
I just download teamviewer software(non-buiness ver) both window 7 Home premium and XP, both computers can connect to each other.
When I disconnect one of computer internet connection, they can NOT connect that actionjust make
sure I am doing to connect to far away remote connection to outside internet. I believe
the both computer dynamic IP address or info is stored into teamviewer's server for as helper
between client and host computer connection
So question
1-Window 7 home Premium can connect to but be being connected , Right ?
2-Window 7 home Premium can be connected but not connect to , Right ?
3-XP home Premium can connect to but be being connected , Right ?
4-Xp home Premium can be connected but not connect to , Right ?
Now on my computer window 7 home Premium, I click computer-?properties_>remote connection it will
show this image at https://forums.lenovo.com/t5/image/serverpage/image-id/32607iFFCB8B9EB6C82DFA/image-size/original?v=mpbl-1&px=-1, Remote Desktap tag
is missing
as I know, normal view should be for higher version of window 7
http://www.softwareok.com/img/faq/Win-7/Change_settings_for_Remote_Desktop_in_Windows-7.png
I don't know it is caused by inherited from window 7 home premium or by virus or not ?
So question
is missing
Expert: David Johnson, CD, MVP replied at 2024-07-26 06:47:19
no no no.. it has the connection ability but not the capability of receiving a connection. it has the client software but not the inbound remote desktop software.
Expert: rindi replied at 2024-07-26 06:46:42
No, call out means you can connect to PC's running the server part of remote desktop.
With anything that goes beyond your router you would need to use something like port forwarding on the router, and you'd also need to know tha IP of the router's WAN connection, which for most users change as most ISP's assign IP's dynamically to their clients. Static IP's are usually optional add-ons that cost more.
Author: duncanb7 replied at 2024-07-26 06:42:22
call out mean just within LAN locally not outside far away remote computers ?
My window 7 home premium can connect to my XP but both are at my some router
and Xp can not connect to window 7 computer.
Please advise if have time
Expert: David Johnson, CD, MVP replied at 2024-07-26 06:39:35
home premium can call out but not receive.
Author: duncanb7 replied at 2024-07-26 06:37:41
I read from internet, some said home premium only connect to other computer but can be NOT connected some said it can be connected by other computers but it can Not connect to. So anyway, just upgrade it for all computers to Prof or ultimate.
Expert: David Johnson, CD, MVP replied at 2024-07-26 06:28:34
The difference between client and server operating systems is also that on a client OS there can be only 1 console user at a time the other user will not be able to access the machine, Servers on the other hand allow for both a local and a remote connection at the same time, each having their own window. I'm not sure whether or not you can have a local operator and 2 remote desktop operators at the same time without terminal services (remote desktop services) running.
Author: duncanb7 replied at 2024-07-26 04:52:06
Note for me only:
-After checking on window chinese version on internet, my version is Windows 7 Home Premium Edition
-other XP computer can NOT connect to my window 7 Home Premium version computer by RDP
- need to upgrade it to Prof or Ultimate version ,and by the way in order to solve switch language issue.
Expert: rindi replied at 2024-07-25 11:49:36
M$ Server OS's include Remote Desktop services, but you have limits in the number of connections, which is 2 maximum (Administrator mode, meant for remote administration). There is also the non admin mode, for that you need additional licenses and a TS licensing server. But that is probably irrelevant for your needs.
Author: duncanb7 replied at 2024-07-25 11:39:14
Any advise ?
Author: duncanb7 replied at 2024-07-25 11:16:13
If I switch from window 7 home premium to window server any version, 2003...2008
that MUST connect to RDC, RIght ?
Third-party VPN will be complex to use since a lot of software option and providers not as standard as window
Expert: rindi replied at 2024-07-25 11:12:39
You can connect from home versions to other "Terminal Servers". You just need a Remote desktop client for that. But in order to act as a server, you need something better than a Windows home version.
Author: duncanb7 replied at 2024-07-25 10:11:45
David, thanks for your reply, please review my previous posts.
I said it is Home Professional or Advanced that is translated by me from chinese font viewing that may be wrong translation
since I don't have English version window on my computer.
Expert: David Johnson, CD, MVP replied at 2024-07-25 10:02:54
Again there is no windows 7 Home Professional Advanced.
The only versions were enumerated before
Windows 7 Starter, Windows 7 Home Basic, Windows 7 Home Premium. Windows 7 Professional, Windows 7 Enterprise, Windows 7 Ultimate
If it is saying anything else then it is a hacked operating system.
Author: duncanb7 replied at 2024-07-25 09:58:43
Thanks for your reply
Author: duncanb7 replied at 2024-07-25 09:57:15
May be tomorrow, I find two computers to connect to RDC to verfiy the one-way direction
reason on RDC
Thanks, your great work
reason on RDC
Author: duncanb7 replied at 2024-07-25 09:54:57
The only reason now I know it
If my window is home premium, it can connected to other computer but other computer can NOT connect to him. form this site
http://answers.microsoft.com/en-us/windows/forum/windows_7-windows_install/does-windows-7-home-premium-support-remote-desktop/0cb69a49-868b-47e0-a760-1a16567413bc
http://windows.microsoft.com/en-us/windows/remote-desktop-connection-faq#1TC=windows-7
So that is why my memory tell me it seems it work before, but actually just only in one way direction not from both direction
Expert: rindi replied at 2024-07-25 09:50:54
Vista is exactly the same. The home versions don't support RDC connections to it. You also can't change languages in the home editions of Windows Vista or 7 without hacks. Language changes are only supported from the Ultimate editions upward (not even the Pro version supports that)
Author: duncanb7 replied at 2024-07-25 09:46:04
I think I need to change it for whole system from Chinese to English , but trouble.
may be talk to your tomorrow. From my memory, I connected this computer before
Last question today, Vista is no issue to RDC for all version right ?
I guess I might switch the OS from vista to window 7
Expert: rindi replied at 2024-07-25 09:41:47
It has nothing to do with 64bit or not. It is the edition. Your comments above don't show the edition.
Author: duncanb7 replied at 2024-07-25 09:40:55
it is HP Pavilion g4 Notebook PC , 64-bit system, 4Gb memory, Interl Pentium(R) CPU P6300 @2.27GHZ 2.27GHz
Author: duncanb7 replied at 2024-07-25 09:38:15
If it is 64-bit processor, it should run RDC now and before ?
Author: duncanb7 replied at 2024-07-25 09:36:20
After check,
it is window 7 6.1.7601 service Pack 1, checked from systeminfo
User-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64) Checked it from online
it is 64-bit , right ?
where WOW emans (Windows-On-Windows 64-bit) A 32-bit application is running on a 64-bit processor
Expert: rindi replied at 2024-07-25 09:34:32
If there is anything like "home" in the description it won't work.
Author: duncanb7 replied at 2024-07-25 09:22:09
Any online check to my window version shown in english or command ?
I am using systeminfo still output Chinese language.
Please wait, as remember the computer was connected to RDC before
Expert: rindi replied at 2024-07-25 09:17:16
You probably mean home premium, there is no Windows 7 home professional. As I said, it isn't and has never been available with any home version of Windows (from XP to Windows 8.x).
Author: duncanb7 replied at 2024-07-25 09:05:06
Since is is in other language I directly translated it , it should be HOME Professional(Advanced) , and the window version is legal one.
DUncan
DUncan
Expert: rindi replied at 2024-07-25 08:57:03
There is no such thing as a Windows 7 home advanced edition. There are Windows 7 starter (only available as 32bit version), Windows 7 home and home premium (neither support Remote Desktop connections), Windows 7 Professional, Ultimate and Enterprise, and only these last 3 support Remote Desktop Connections to them.
If you have something different, or if it used to work with your home version, then you used a crack which is a breach against m$'s eula, and helping with anything like that isn't allowed on this site.
Author: duncanb7 replied at 2024-07-25 08:41:59
It worked before on the same computer and same version of window 7 home Advanced Edition.So it is not window version issue. But why now it is not working
Expert: rindi replied at 2024-07-25 08:35:47
Remote Desktop as a Service is only available on the non-home editions of Windows. So you need at least Windows 7 Pro.
