When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by SQLSearcher
at 2024-07-25 03:09:58
Point:500 Replies:3 POST_ID:829100USER_ID:11980
SQL Server 2008;;Spreadsheet Software
Hello Experts Exchange
I currently have a Excel 2010 spreadsheet that has formulas in it that only work when I go in to the cell and press enter.
The formulas in the cells are like the following;
='J: 7AC4Moulding[MouldingRed561.xls]Production'!AD141+'J: 7AC4Moulding[MouldingBlue561.xls]Production'!AD141+'J: 7AC4Moulding[MouldingYellow561.xls]Production'!AD141
Is there a way to get the formulas to update automatically?
Regards
SQLSearcher
Regards
SQLSearcher
Expert: duncanb7 replied at 2024-07-25 03:45:51
300 points EXCELLENT
I think you need to stop auto recalculation on Excel cells from automatic to manaul
as the instruction at this site
http://www.dummies.com/how-to/content/controlling-excel-2007-formula-calculations-manual.html
After that, you can click cell and press enter, the cell will calculate it again
Expert: helpfinder replied at 2024-07-25 03:44:59
200 points EXCELLENT
try to press CTRL+ALT+F9 if the formulas will be recalculated.
also check if your cell formatting is not text, so you can try to change to general and then CTRL+ALT+F9 to recalculate formulas
Expert: Vikas Garg replied at 2024-07-25 03:12:21
It is not related to SQL ...
