When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by PeterBaileyUk
at 2024-07-25 02:43:55
Point:500 Replies:19 POST_ID:829099USER_ID:11868
Microsoft Access Database;;
I have created an array by using the split function.
ClientWords = Split(Trim(txt))
I would like to do a redim preserve to add an extra element so I can mark a specific word in the array.
How do i do that
I tried ReDim Preserve ClientWords(UBound(ClientWords),0)
but i get subscript out of range
How do i do that
Expert: eenookami replied at 2024-07-29 17:35:02
Peter/Dale/Jell,
Thank you and appreciate you returning to the question to clarify it for Duncan's benefit.
eenookami
CS Moderator
eenookami
CS Moderator
Author: PeterBaileyUk replied at 2024-07-28 09:35:44
It seems you all answered your own things, the solution provided by Jell at that time was the best solution, I believe I am always fair when dishing out points (I think fyed would agree) if I have two that work then I usually share but in this case Jell understood perfectly the requirement. Hence the full points. In fact I had already posted the first part hence I ignored the "range" it was the addition of the second array that completed the task.
Expert: Dale Fye (Access MVP) replied at 2024-07-28 06:40:14
Nope, Jell has a good working solution that works in Access VBA.
Expert: James Elliott replied at 2024-07-28 05:29:29
Maybe my interpretation of the question would help:
The OP wanted to be able to tag certain words in his one-dimensional array, created using the split function.
I provided a solution which copied the 1-d array to a 2-d array, so that he could place a tag (in the second dimension) next to each word if he wished to.
Expert: eenookami replied at 2024-07-28 05:21:16
PeterBaileyUk,
Duncanb7 has asked for clarification of the solution. It would seem he is not the only one.
Experts, it's there any reason to change the points distribution here? Please advise.
eenookami
CS Moderator
eenookami
CS Moderator
Expert: Dale Fye (Access MVP) replied at 2024-07-25 04:22:27
jell,
nothing. I focused in on "Range". After I posted the comment I realized you had basically recommended the same thing that I did, use a second array.
Expert: James Elliott replied at 2024-07-25 04:08:42
fyed,
what, aside from my testing my code in Excel and forgetting to take out the 'range' reference, makes it an "Excel" solution?
Expert: duncanb7 replied at 2024-07-25 04:02:46
Dear Author,
from your post , it seems you want add one more cell into array.
but you want multi-dimension array,
Thanks for your reply
Expert: Dale Fye (Access MVP) replied at 2024-07-25 03:58:50
Peter,
I'm confused. You posted to an Access topic area, yet accepted an Excel solution?
Expert: Dale Fye (Access MVP) replied at 2024-07-25 03:56:34
I don't believe you can use redim to change the number of dimensions in an array.
You could write your own code to do this with a 2 dimensional array
Dim xWords() As String
Dim ClientWords() As Variant
xWords = Split("Your text string goes here")
ReDim ClientWords(UBound(xWords), 1)
For x = LBound(xWords) To UBound(xWords)
ClientWords(x, 0) = xWords(x)
Next
Next
Expert: duncanb7 replied at 2024-07-25 03:41:23
Dear Author,
Is the code matched to your question post?
Author: PeterBaileyUk replied at 2024-07-25 03:38:25
thank you
Author: PeterBaileyUk replied at 2024-07-25 03:34:41
our responses are crossing just seen 40219078
Author: PeterBaileyUk replied at 2024-07-25 03:33:49
I must have said it wrong the split creates the array fine I need to add another dimension so I can flag them
Expert: James Elliott replied at 2024-07-25 03:32:23
See if this helps at all:
Sub SplitWithTag()Dim arr As VariantDim arrTag As VariantDim x As Longarr = Split(Range("A1"))ReDim arrTag(UBound(arr), 1)For x = LBound(arr) To UBound(arr) arrTag(x, 0) = arr(x) arrTag(x, 1) = "Your tag"Next xEnd Sub 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:
Expert: duncanb7 replied at 2024-07-25 03:26:28
try this with UBound
Sub Test()Dim ClientWords() As StringClientWords() = Split("How are you")Debug.Print UBound(ClientWords, 1)ReDim Preserve ClientWords(UBound(ClientWords, 1) + 1)Debug.Print UBound(ClientWords, 1)ClientWords(UBound(ClientWords, 1)) = "Today"Debug.Print ClientWords(UBound(ClientWords, 1))End Sub 1:2:3:4:5:6:7:8:9:
Author: PeterBaileyUk replied at 2024-07-25 03:26:05
heres my code so far its just a question of tagging i thought adding an extra element would allow that
ClientWords = Split(Trim(txt)) For x = LBound(ClientWords) To UBound(ClientWords) Step 1 With rstWordExceptions .MoveFirst 'cycle through the query grabbing strings Do Until .EOF If ClientWords(x) = rstWordExceptions.Fields("sdesc").Value Then Else End If rstWordExceptions.MoveNext Loop End With Next x 'loop to next word in array 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:
Author: PeterBaileyUk replied at 2024-07-25 03:24:49
vba gives compile error method or data member not found on counta
I have
207
s16
1.6
[120]
I want it to go through a record set and if it finds the current word clientwords(1) s16 in this case it will tag 16 so i can use that later.
I have
207
s16
1.6
[120]
Expert: duncanb7 replied at 2024-07-25 03:15:46
Is it what you want for redim ?
Hope understand your question.If not, pls pt it out
Sub Test()Dim ClientWords() As StringClientWords() = Split("How are you")'Debug.Print ClientWords(1)ReDim Preserve ClientWords(Application.CountA(ClientWords))ClientWords(Application.CountA(ClientWords) - 1) = "Today"Debug.Print ClientWords(3)End Sub 1:2:3:4:5:6:7:8:
