When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by YellowbusTeam
at 2024-07-25 02:34:25
Point:500 Replies:7 POST_ID:829098USER_ID:11998
Windows Server 2012;;Hard Drives & Storage
Hi ,
Our client has a server 2012 and on the E drive which is just a shares drive its showing on the properties of the Drive that it is using 145GB but when i do a treesize it shows only 94 GB used.
I have not set up shadowcopy on this drive and there are no hidden files.
Any help would be aprreciated.
Regards
Matt
Regards
Matt
Expert: skullnobrains replied at 2024-07-30 11:53:07
if you found the remaining hidden 39GB (145-94+12 in the recycle bin) the answer may benefit others (including myself). thanks for sharing if possible. regards
Author: YellowbusTeam replied at 2024-07-30 03:21:22
I have attached screenshots as requested. There is no pagefiles on this partition or datastreams, i hve just used spacesniffer and its showing a 12gb in the $recycle bin.
Expert: skullnobrains replied at 2024-07-26 10:43:54
if you are admin, the remnant candidates are (might not be exhaustive)
- recycle bin (first most obvious and often forgotten possibility)
- system files : namely a huge pagefile.sys that may be located on the E drive, or possibly windows updates remnants (can't think of anything else that could take that much space). there is a specific setting in explorer (next to the hidden files) that will let you display system files. i'm unsure of treesize's behavior regarding system files when they are hidden in windows explorer.
- Alternate Data Streams. quite unlikely and would be the sigh of virus corruption or someone voluntarily messing with the system. i remember a rather old virus that would clutter a drive with ads until there was no disk space and that produces many strange crashes, because the system would think it had some space left while it did not. i'm unsure how the corresponding space is accounted currently but i'd assume it now shows in the total size but not in each file size.
- misnamed files : this can happen even involuntarily with some non MS clients when you store files with unsupported characters and/or charsets (UTF8 "" for example). this will confuse software such as the explorer or treesize (which will quite often simply not display the file) but the files still take space. files that start with a dot can also do weird things in windows.
- failing filesystem. i deem this very unlikely given the size of the missing space and the fact it would most likely produce tons of alerts you would have noticed by now, but it is not 100% impossible.
btw, what is the overall size of the drive ?
Expert: nobus replied at 2024-07-25 23:25:57
you can also run a chkdsk /f on the drive - it helps often
Expert: duncanb7 replied at 2024-07-25 04:17:19
Probably or most likely, David is correct completely.
TreeSize may not be reporting data based on where it does not have permissions (this is not the same as a hidden or protected OS file). The drive properties will report total disk utilization.
Expert: David Johnson, CD, MVP replied at 2024-07-25 03:36:47
you must run treesize as an administrator to get accurate results
Expert: Dirk Mare replied at 2024-07-25 03:08:12
Have you had a look at System files/settings?
Page file, recycler ext?
Can you post screenshots of Disk management, E drive properties and treesize?
DirkMare
DirkMare
