When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by StevenHook
at 2024-07-25 00:12:14
Point:500 Replies:8 POST_ID:829096USER_ID:11995
Microsoft Excel Spreadsheet Software;Microsoft Office Suite;Office Suites
I have a spreadsheet with names and dates to be printed onto certificates.
The dates are formatted in excel to look like "9 July 2014" but when you double-click the cell it reads 9/7/14 in the formula bar. and in the print software it's picking up as "9/7/14"
Is there not a way to copy the formatted date text from that column and paste it as text instead of as a date?
Steve
Steve
Author: StevenHook replied at 2024-07-25 01:59:39
That looks like it's working - thanks!
Expert: duncanb7 replied at 2024-07-25 01:02:18
300 points EXCELLENT
you can convert it to text from A1="9 Jan 2014" to B1 with this formula
=TEXT(B1,"dd mmmm yyyy"),
Is it what you need?
Expert: Rob Henson replied at 2024-07-25 00:58:29
200 points EXCELLENT
If you are not using the date for any calculations convert it to text using the following formula, assuming date in column B:
=TEXT(B2,"dd mmmm yy")
Then copy and paste values to overwrite if so required.
Rob H
Rob H
Expert: duncanb7 replied at 2024-07-25 00:51:58
Now I know it, it is normal, why you double-click the cell? for what ?
Author: StevenHook replied at 2024-07-25 00:35:40
I'm sorry, you're not understanding the problem.
The dates are formatted in excel to look like "9 July 2014" (which is what we want) but when you double-click the cell it reads 9/7/14 in the formula bar. and in the print software it's picking up as "9/7/14"
Expert: duncanb7 replied at 2024-07-25 00:28:28
Since the cell you paste is formated to number
so you should do it not just copy cells bus paste cells also
Author: StevenHook replied at 2024-07-25 00:24:45
Yes, we have formatted it correctly like that. so it looks right on the sheet.
But when you copy it, or it copies 9/7/14 or when you format as text it gives some number other strange number (like maybe 5 or 6 digits)
Steven
Steven
Expert: duncanb7 replied at 2024-07-25 00:18:13
You can select the cells you want, and mouse right-click->format cells
There is a lot of options for date such as "11 Jun 2014"
Take a look at Excel on Mac for format cell insruction
http://www.dummies.com/how-to/content/office-2011-for-mac-format-dates-and-times-in-exce.html
