When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by jrsitman
at 2024-07-24 14:39:48
Point:500 Replies:15 POST_ID:829095USER_ID:11994
Windows Server 2008;;
I need the registry settings that control the taskbar setting "properties, show small icons". Also the desktop settings "view, small icons".
Expert: duncanb7 replied at 2024-07-25 19:08:44
Author: jrsitman replied at 2024-07-25 15:53:39
Author: jrsitman replied at 2024-07-25 15:52:28
That worked.
Expert: duncanb7 replied at 2024-07-25 08:59:36
Try this at command line
REG ADD "HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionExplorerTaskband" /v "Favorites" /t "REG_BINARY" /d "" /f
Author: jrsitman replied at 2024-07-25 08:50:26
see attachment
Expert: duncanb7 replied at 2024-07-25 08:47:42
pin items, what your mean ?
Expert: duncanb7 replied at 2024-07-25 08:47:01
No, I don't understand your question 3? Please write it in detail
Author: jrsitman replied at 2024-07-25 08:45:52
so you want me to post a new question on EE for #3?
Expert: duncanb7 replied at 2024-07-25 08:43:23
are you taking about question 1 , right ? Or new question,
please review my previous post
Author: jrsitman replied at 2024-07-25 08:42:19
When I pin items to the taskbar, the next time I log on they are not there. So I need to check what registry setting saves items pinned to taskbar.
thanks
thanks
Expert: duncanb7 replied at 2024-07-25 07:04:13
Actually, now your two questios has been solved from your question post ,Right ?
Now you want to add third question for
Right ? COuld you write it more in detail about question-3
Please verify this first, otherwise confusing
How about the setting to save keep icons on taskbar?
Author: jrsitman replied at 2024-07-25 06:50:47
Sorry I made the wrong entry. Desktop is working. How about the setting to save keep icons on taskbar?
Expert: duncanb7 replied at 2024-07-25 06:40:39
Value Data: Size in Pixels (Default = 32)
Did you change other size you want besides 32 ?
Author: jrsitman replied at 2024-07-25 06:34:26
the small taskbar worked but not the desktop. See screen shot for clarification.
In addition I need the registry setting to retain items placed on taskbar.
Thanks for helping.
Thanks for helping.
Expert: duncanb7 replied at 2024-07-25 05:03:07
using regedit editor at command shell by "regedit" for taskbor small icon to change
the following key
HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionExplorerAdvanced
"TaskbarSmallIcons"=dword:00000001
For small icons,set the dWord value to 1.
For desktop small size view:
User Key: [HKEY_CURRENT_USERControl PanelDesktopWindowMetrics]
Value Name: Shell Icon Size
Data Type: REG_SZ (String Value)
Hope understand your question.If not, pls pt it out
the following key
