When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by xmouser
at 2024-07-24 09:59:35
Point:500 Replies:7 POST_ID:829093USER_ID:11921
Microsoft Excel Spreadsheet Software;;Microsoft Office Suite
I have a spreadsheet with 90,000 rows and 10 columns. I need to find out how many of the cells contain a specific value. Let's say 538. How many cells have 538 their cell. I've tried to sort but the it's so unwieldy the program craps out. Sorting hangs and never recovers.
Any quick and simple method to extract this one bit of info?
Author: xmouser replied at 2024-08-04 06:12:18
Sorry for the delay I've been out for a week.
Author: xmouser replied at 2024-07-24 12:48:44
Typo on my part.
Expert: duncanb7 replied at 2024-07-24 11:05:08
Please take a look the Excel tutorial at this site if have time
http://www.techonthenet.com/excel/formulas/countif.php
Expert: duncanb7 replied at 2024-07-24 11:03:25
it is COUNTIF not COUNT
Author: xmouser replied at 2024-07-24 11:02:09
=COUNT(F1:F99360, 538) gives me 99361 which is wrong, it give me 99361 no matter what value I'm looking for.
=COUNT(F1:F99360, 540) gives me 99362, etc.
Expert: duncanb7 replied at 2024-07-24 10:30:48
200 points EXCELLENT
NBVC is correct, and I modify this from him
=COUNTIF(A:Z,538)
That you don't need to consider the number of row to be searched when
put the formula out of A:Z range , ie, put it at Cell AA
=COUNTIF(A:Z,538)
Expert: NBVC replied at 2024-07-24 10:06:09
300 points EXCELLENT
You can use COUNTIF
e.b.
=COUNTIF(A1:Z100,538)
e.b.
