When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by dravidnsr
at 2024-07-24 01:27:34
Point:500 Replies:9 POST_ID:829087USER_ID:11987
Java Programming Language;;J2EE
Hi i have ah string like this
String s = add(add(12,5),5)
I want to split this first i want to do inside add then come to out side
Expert: awking00 replied at 2024-07-25 12:37:18
I suspect your example is a sample representation of some real data that probably has more than one variation. Perhaps you can provide some different samples and, most importantly, an explicit explanation of the criteria to employ to produce your desired results.
Expert: rrz replied at 2024-07-24 08:52:27
If you want
add(add(12,5),5) to change to No((no(12)+no(5))+no(5))
import java.util.regex.*;public class Test { public static void main(String args[]){ String s = "add(add(12,5),5)"; Pattern p = Pattern.compile("-?\d+"); Matcher m = p.matcher(s); StringBuilder sb = new StringBuilder("No(("); while (m.find()) { sb.append("no(" + m.group() + ")+"); } sb.deleteCharAt(sb.length() - 1); sb.append(")"); System.out.print(sb.toString()); }} 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:
Expert: CEHJ replied at 2024-07-24 05:25:47
Sorry - no. I have no experience with it personally
Author: dravidnsr replied at 2024-07-24 04:00:46
Chj can you tell how implement in my example string
Expert: CEHJ replied at 2024-07-24 02:37:06
Author: dravidnsr replied at 2024-07-24 02:18:31
Praser?? Can you give some example?
Expert: CEHJ replied at 2024-07-24 01:43:02
You can't really handle nesting well with regular expressions. What you're doing is dealing with a mini-language so you need to create a parser for it
Expert: duncanb7 replied at 2024-07-24 01:36:17
Why you mention split string ? If using split() to split string with delimiter
of "-",for example, the code will be this
String string = "004-034556";String[] parts = string.split("-");String part1 = parts[0]; // 004String part2 = parts[1]; // 0 1:2:3:4:
Could you write it more and in detail
Author: dravidnsr replied at 2024-07-24 01:34:13
I want yo change that into
No((no(12)+no(5))+no(5)) how do this
