When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by hkgal
at 2024-07-24 00:16:54
Point:500 Replies:5 POST_ID:829086USER_ID:11986
Microsoft Excel Spreadsheet Software;VB Script;Visual Basic Programming
Hello! I tried to do a countif function by VBA in Excel, by excel it should be like = countif("A:A",A2) .... like this and map the count to Column Z.
However my code below return all zero value......where am I get wrong? pls help....thanks.
Sub countsff()
Dim sffCount As Long
LastRow = Range("A" & Rows.Count).End(xlUp).Row
For Idx = 2 To LastRow
sffCount = Application.WorksheetFunction.CountIf(Range("A" & Rows.Count), Cells(Idx, "A").Value)
Cells(Idx, "Z") = sffCount
Next
End Sub
Sub countsff()
Next
End Sub
Expert: duncanb7 replied at 2024-07-24 02:09:41
Author: hkgal replied at 2024-07-24 01:41:47
Thanks! mate
Expert: Glenn Ray replied at 2024-07-24 01:02:38
You appear to only be checking the last cell in column A against all values in A. I would have expected the last value in column Z to be 1, however.
Try this revision to your code:
Sub countsff() Dim sffCount As Long LastRow = Range("A" & Rows.Count).End(xlUp).Row For Idx = 2 To LastRow sffCount = Application.WorksheetFunction.CountIf("A:A", Cells(Idx, "A").Value) Cells(Idx, "Z") = sffCount Next IdxEnd Sub 1:2:3:4:5:6:7:8:
Regards,
-Glenn
Sent from my Windows Phone
Expert: duncanb7 replied at 2024-07-24 00:59:09
It should be this, Right ?
sffCount = Application.WorksheetFunction.CountIf(Range("A1:A" & LastRow), Cells(Idx, "A").Value)
Sub countsff()Dim sffCount As LongLastRow = Range("A" & Rows.Count).End(xlUp).RowFor Idx = 2 To LastRowsffCount = Application.WorksheetFunction.CountIf(Range("A1:A" & LastRow), Cells(Idx, "A").Value)Cells(Idx, "B") = sffCountNextEnd Sub 1:2:3:4:5:6:7:8:
Expert: Steve replied at 2024-07-24 00:56:17
Are you on the right sheet?
It may be good practice to Dim and use the sheet:
And the range needs to have a from A1 added.
See below...
See below...
Sub countsff() Dim sffCount As Long Dim ws as worksheet Set ws = sheets("Sheet1") LastRow = ws.Range("A" & Rows.Count).End(xlUp).Row For Idx = 2 To LastRow sffCount = Application.WorksheetFunction.CountIf(ws.Range("A1:A" & ws.Rows.Count), ws.Cells(Idx, "A").Value) ws.Cells(Idx, "Z") = sffCount Next End Sub 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:
or drop the rows count from the line:
sffCount = Application.WorksheetFunction.CountIf(ws.Range("A:A"), ws.Cells(Idx, "A").Value) 1:
