When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by brgdotnet
at 2024-07-23 22:07:22
Point:160 Replies:9 POST_ID:829085USER_ID:10
jQuery;;
In JQuery,
is $(document).ready(function() the same as $(function () { }
Expert: Rob Jurd replied at 2024-07-27 19:11:32
To clarify,
$(document).ready(function() {}); is capturing the "ready" event when the document had loaded.
$(function() {}); is passing an anonymous function to the jQuery class. JQuery is configured such that the anonymous function is only called once the DOM has loaded.
More info on frameworks here:
http://www.experts-exchange.com/Programming/Languages/Scripting/JavaScript/A_12264-Javascript-Frameworks-what-are-they.html
And JavaScript objects (that is all jQuery is)
http://www.experts-exchange.com/Programming/Languages/Scripting/JavaScript/A_13138-Javascript-is-just-an-Object.html
Expert: eenookami replied at 2024-07-27 18:52:51
Force accept. There is no difference between the two. One is short hand for the other
Expert: duncanb7 replied at 2024-07-24 02:57:26
Thanks for your reply , please review my post I didn't suggest anything and I just verify it by testing for all of you from your previous post to me.
The answer is Yes to the question and mentioned at this site
http://learn.jquery.com/using-jquery-core/document-ready/
Expert: Scott Fell (padas) replied at 2024-07-24 02:55:47
Thank you Duncan. Your description matched something for pure javascript. If you add the $ or jquery in front, now you are talking about jquery as you suggest, but then the description you gave is incorrect.
The simple correct answer to the question,
Yes, they are both the same.
Expert: duncanb7 replied at 2024-07-24 02:50:39
Scott, you agree ?
Expert: duncanb7 replied at 2024-07-24 02:42:53
Scott, you are correct and I miss $
And the article mention $(function()) is shorthand for $( document ).ready() at this site. http://learn.jquery.com/using-jquery-core/document-ready/
And my previous post is shown the different between $(document.)ready() and (function()) , javascript self-start function only.
You can test from the following code , if the div tag change color means it work for the code. Finally, it showed only Self-javascript function can not change to green color.
<html><meta http-equiv="Content-Type" content="text/html; charset=Big5"><head><title>Title</title><style></style><script src="/js/jquery.min.js" type="text/javascript"></script><script src="/js/jquery-ui.min.js" type="text/javascript"></script><script type="text/javascript">(function() { document.getElementsByClassName('tap')[0].style.color="Green";});$(function() { document.getElementsByClassName('tap')[1].style.color="Green";});$(document).ready(function() {document.getElementsByClassName('tap')[2].style.color="Green";});</script><script type="text/javascript"></script></head><body ><div class="tap">Self-javascript</div><div class="tap">$(function())</div><div class="tap">Ready-jquery</div></body></html> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:
Expert: Scott Fell (padas) replied at 2024-07-24 01:50:39
@duncanb7, I'm just trying to double check because we seem to have different answers for the same thing.
I may be confused, but are you talking about pure javascript? or jquery?
self calling anonymous function that is just function, it will operate or start as soon as possible when the browser is interpreting your ecma-/javascript
Expert: Scott Fell (padas) replied at 2024-07-24 00:31:20
160 points EXCELLENT
These two sets of code below are the same http://api.jquery.com/ready/. I personally use the later because it is faster to type out.
Expert: duncanb7 replied at 2024-07-23 23:19:35
There is different between
At $(document).ready(function(),
The function() will operate after the whole page is completely loaded and DOM is ready.
But
$(function () { }
is self-start or self calling anonymous function that is just function, it will operate or start as soon as possible when the browser is interpreting your ecma-/javascript regardless the page being loaded completely or not
But
$(function () { }
