When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by jbobst
at 2024-07-23 09:06:35
Point:500 Replies:9 POST_ID:829082USER_ID:11984
General Computer Systems;Personal Computers;Miscellaneous Hardware
We just got a new Lenovo desktop to replace one of our aging desktop machines. In this desktop, we use a PCI adapter card which allows us to plug in a PCMCIA card (high end audio card) into the desktop. On our new desktop, there is only one older PCI slot (the rest are all PCI-E slots). After we plugged in the PCI adapter card and turned on the new desktop, we get a POST error saying:
Error resource conflict - PCI in slot 1
Bus:06, Device:0d, Function:00
And, when Windows launches, the device has an error which says it's in conflict. I Plugged in a couple other random PCI cards (sound card, NIC) and they don't have this error. I also tried another PCI to PCMCIA adapter card and it gives the same error. I've gone through every option in the BIOS trying to see if I could change any of the "addresses" of various resources, but there is nothing. I've also done things like disabled the serial port in BIOS but that doesn't help either. What can I do to figure out what device is in conflict and change resources? In device manager, the adapter card doesn't allow me to change the resource settings.
Expert: coral47 replied at 2024-08-05 16:34:45
That's one way to "skin a cat". Nice going. : D
Thanks for the feedback, and the Points. : )
Author: jbobst replied at 2024-08-05 16:10:22
So sorry for the delay in this thread. I actually found a PCI-e 1x card that was an "express card slot" and I used and express card to PCMCIA adapter to get my device working. I didn't haven't a chance to disable the onboard sound, but I need the onboard sound card for other purposes so that would not have been ideal.
Expert: coral47 replied at 2024-07-24 16:16:51
Did you try Disabling the Onboard Sound, in the BIOS?
Expert: duncanb7 replied at 2024-07-23 10:35:36
how device manager, do you find any in red cross X mark after you click those ALL device icon ?
Please type at command shell to activate device manager
mmc devmgmtmsc
mmc devmgmtmsc
Author: jbobst replied at 2024-07-23 10:32:42
This is a Windows 7 64bit system on a Lenovo S20 workstation. I'll look into the systeminfo.exe.
Expert: duncanb7 replied at 2024-07-23 09:38:49
what is system ? what window or what linux dist ?
You can collect all system information on window on command shell
systeminfo.exe
On Linux, you can do this a lot way at this site
http://www.binarytides.com/linux-commands-hardware-info/
systeminfo.exe
Expert: duncanb7 replied at 2024-07-23 09:28:27
Go to this site to find out device manager on window or command line such as
mmc devmgmtmsc
http://technet.microsoft.com/en-us/library/cc754221(v=ws.10).aspx
And you can click all device to see any device is in red color or not
mmc devmgmtmsc
Author: jbobst replied at 2024-07-23 09:23:19
Let me give a few more details...I think I understand your question. The new desktop works just fine without the PCI adapter card plugged in. No hardware issues. In addition, we actually received 6 new desktop machines, so I grabbed another machine just to make sure there wasn't something wrong with the first machine I tried. The second machine has the same error when the PCI card is installed. Also, there is no driver for this PCI card. It uses some basic Windows driver (similar to laptops that have a PCMCIA card slot built in). Once I put the PCMCIA card in the adapter, I do need a driver but, I am not even at that point yet. The new desktops have this POST error, and even if I continue to boot into windows, the adapter card had resource conflicts in device manager. Our old desktops never had these issues.
Expert: duncanb7 replied at 2024-07-23 09:16:47
The boot or reboot on new desktop is no any issue, Right ? You can
run any other application such video, broswer surf, Right ?
No audo sound, right ?
The hardware device has issue may not be the device confict to your
system that may be from device software driver.
Could you try to download the latest driver for your new desktop from Lenovo or vendor website ?
Hope understand your question completely.if not pls pt it out
