When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Wilder1626
at 2024-07-23 08:00:32
Point:500 Replies:5 POST_ID:829080USER_ID:11982
Visual Basic Programming;;
Hi.
I would like to know how i can force the web link to open with Firefox and still leave IE as the default browser.
Is that possible?
Thanks for your help
Is that possible?
Private Declare Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA" (ByVal hwnd As Long, ByVal lpOperation As String, ByVal lpFile As String, ByVal lpParameters As String, ByVal lpDirectory As String, ByVal nShowCmd As Long) As Long ShellExecute Me.hwnd, vbNullString, _ "www.google.ca", _ vbNullString, App.Path, SW_SHOWNORMAL 1:2:3:4:5:
Author: Wilder1626 replied at 2024-07-25 05:29:23
Thanks a lot for the help. This is working great.
Expert: Chris Watson replied at 2024-07-23 09:34:31
I like Randy's suggestion for improving the robustness of the strategy.
It seems that the location of the Firefox executable is stored in the registry. The correct key is dependant upon a few things, including the version number of Firefox installed and the version of Windows in use.
For example, for Firefox 30 on Windows 7 (64-bit) the registry path is:
HKEY_LOCAL_MACHINESOFTWAREWow6432NodeMozillaMozilla Firefox30.0 (en-GB)MainPathToExe 1:
Expert: duncanb7 replied at 2024-07-23 08:18:42
it seems he want to get the handler of hwnd from firefox application as we did it for IE
Author, please write more about this if it is
Expert: Randy Poole replied at 2024-07-23 08:09:32
What Chris said is correct to a point, you would need to query the registry first to see where firefox is installed.
Expert: Chris Watson replied at 2024-07-23 08:08:18
Shell "C:Program Files (x86)Mozilla FirefoxFirefox.exe ""http://www.google.ca""", vbNormalFocus 1:
Provided that Firefox is installed in the standard location on a 64-bit PC this will open http://www.google.ca in Firefox without requiring changing the default browser. If Firefox is installed in a different location, update the path accordingly.
