When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by SQLSearcher
at 2024-07-23 01:04:20
Point:300 Replies:6 POST_ID:829079USER_ID:11980
Spreadsheet Software;Microsoft Office Suite;Microsoft Excel Spreadsheet Software
Hello Experts Exchange
I have some code for Excel that will create one record from the data I have attached.
The code works if I have the table of data on row 1 and starting in column A, how do I change the code so that it works on row 7 like the example I have attached?
This is the code;
This is the code;
Sub Normalize() Dim SourceRange As Range Dim SourceArr As Variant Dim r As Long, c As Long Dim DestR As Long ' Update as needed Const StartDate As Date = #6/1/2014# ' Update as needed Set SourceRange = ActiveSheet.Range("a1:ak13") SourceArr = SourceRange.Value Worksheets.Add Range("a1:f1").Value = Array("Die", "Machine", "Part Desc", "Part No", "Date", "Units") DestR = 2 For r = 4 To UBound(SourceArr, 1) For c = 7 To UBound(SourceArr, 2) If SourceArr(r, c) <> "" Then Cells(DestR, 1) = SourceArr(r, 1) Cells(DestR, 2) = SourceArr(r, 2) Cells(DestR, 3) = SourceArr(r, 3) Cells(DestR, 4) = SourceArr(r, 4) Cells(DestR, 5) = StartDate + SourceArr(1, c) - 1 Cells(DestR, 6) = SourceArr(r, c) DestR = DestR + 1 End If Next Next MsgBox "Done"End Sub 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:
Regards
SQLSearcher
Attachment:Losses-Example2.xls
Expert: Glenn Ray replied at 2024-07-23 11:52:47
50 points EXCELLENT
SQLSearcher,
RE: skipping zero values
Change line 26 of Patrick's code to
Regards,
-Glenn
Author: SQLSearcher replied at 2024-07-23 06:09:50
Hello Patrick
What change do I have to make to the code if I want it to skip cells that have a zero in them?
Regards
SQLSearcher
Regards
SQLSearcher
Expert: Patrick Matthews replied at 2024-07-23 04:25:40
This changes things a bit, using constants to define where to find the data. Update the constants as needed.
Sub Normalize() Dim SourceRange As Range Dim SourceArr As Variant Dim r As Long, c As Long Dim DestR As Long ' Update as needed Const StartDate As Date = #6/1/2014# Const LastRow As Long = 19 Const DateOffsetRow As Long = 7 Const DataStartRow As Long = 10 Set SourceRange = ActiveSheet.Range("a1:ak" & LastRow) SourceArr = SourceRange.Value Worksheets.Add Range("a1:f1").Value = Array("Die", "Machine", "Part Desc", "Part No", "Date", "Units") DestR = 2 For r = DataStartRow To LastRow For c = 7 To UBound(SourceArr, 2) If SourceArr(r, c) <> "" Then Cells(DestR, 1) = SourceArr(r, 1) Cells(DestR, 2) = SourceArr(r, 2) Cells(DestR, 3) = SourceArr(r, 3) Cells(DestR, 4) = SourceArr(r, 4) Cells(DestR, 5) = StartDate + SourceArr(DateOffsetRow, c) - 1 Cells(DestR, 6) = SourceArr(r, c) DestR = DestR + 1 End If Next Next MsgBox "Done"End Sub 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:
Expert: duncanb7 replied at 2024-07-23 03:37:25
What Excel 2003 or 2007 are you using ?
Author: SQLSearcher replied at 2024-07-23 03:00:54
Hello Duncan
The code works on the table of data when the data is stored on the top of the work sheet, however the spreadsheets that I need the code to work on the table is stored on row 7. I have tried to change the code to reflect the change in location but it keeps failing on the line of code;
Range("a1:f1").Value = Array("Die", "Machine", "Part Desc", "Part No", "Date", "Units") 1:
I think it just needs a couple of changes to work but I have had a play with it but unable to get it to work for me.
The spreadsheet I have attached is a example sheet of how the data is stored, and on sheet2 is example of how I want the data.
Regards
SQLSearcher
Expert: duncanb7 replied at 2024-07-23 02:44:27
Could it explain in detail for the question. What you want to
do on Row1 and Row7
do on Row1 and Row7
