When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-07-22 05:33:45
Point:500 Replies:19 POST_ID:829069USER_ID:11059
VMware;Virtual Private Networking (VPN);Network Operations
Today I have studied between VLAN and VPN at this sites or other external site
http://www.differencebetween.com/difference-between-vlan-and-vs-vpn/
and I understand the VPN is secure connection through authentication check and through public internet network which is not secure. Most likely working VPN example, we remotely login our company network at home through VPN
The question, if company itself has apache server located inside the company for login page with authentication check , for example, connect SSL site at https://mycompany.com/localhost/login..php , and then the empolyees will login into the company local network automatcially. If so , why we need so much third-party VPN software to do that in the past ?
For VMware company, actually I just know the company the solution to let your have Linux and Window system in the same computer and could be easily switched to each system on the same computer. How is related VMware software to VPN and VLAN? And what other service they provide so that they are ranked into large scale company like yahoo or Oracle company
What is the best example software tools to let others to know what this Vmware is doing for ?
Author: duncanb7 replied at 2024-07-22 06:59:34
Thanks for all of your reply
Author: duncanb7 replied at 2024-07-22 06:56:17
It is good start to know what VMware is at this site
https://www.youtube.com/watch?v=xXSsVSGsrJo
DUncan
DUncan
Author: duncanb7 replied at 2024-07-22 06:40:02
people are using his server like hosting company and use Vmware software after remotely
login on users computer. That is similar to Cpanel software on user web browser from hosting
company ?
What special feature they offer ?
company ?
Expert: Andrew Hancock replied at 2024-07-22 06:35:22
62 points EXCELLENT
Because VMware is the WORLD Leader in Virtualisation for Desktops, Servers, Cloud.
VMware does not rent computers, it provides software and Cloud Services.
Author: duncanb7 replied at 2024-07-22 06:29:13
Thanks Wilde_Admin,
Dear Andrew, could you write more about VMware ? I have visited his site but why he is such big
company ?
company ?
Expert: Wilder_Admin replied at 2024-07-22 06:24:09
63 points EXCELLENT
Yes since Windows 2000 only the name changed more or less. RAS was the name in Windows 2000 and since 2008r2 its direct access. More or less
Author: duncanb7 replied at 2024-07-22 06:20:02
Last question to Widler_Admin, all window servers such as window 2008, window 2012, as already have VPN function, right ?
Author: duncanb7 replied at 2024-07-22 06:17:46
I know it is impossible to ask company IT guys to made up VPN software, just the concept,
The company apache server can be configured to VPN server if they are able to do or excellent on network programming by himself without buying expensive third-party VPN tools
Sure ?
Sure ?
Expert: Wilder_Admin replied at 2024-07-22 06:14:34
62 points EXCELLENT
Sure but there allready who built allready a tire so you should not produce another one. By the way there are some of these features already implemented like windows server can vpn or new direct access. Everthing is a matter of spending money or time.
Author: duncanb7 replied at 2024-07-22 06:12:58
Andrews, could you write more in detail,
VMware is rental for computers to users , what they are special if the user and company has its own IT guys and computer servers ?
Expert: Andrew Hancock replied at 2024-07-22 06:11:00
62 points EXCELLENT
VMware is a company which provides Server, Desktop and Cloud virtualisation technologies.
VMware has nothing to do with VPN.
VLAN - virtual local area networks, which can be configured for use with virtualisation.
VMware website is here http://www.vmware.com
Author: duncanb7 replied at 2024-07-22 06:09:55
How about saying that, the company apache server can configured to be VPN server if company
aministrator/IT guys is really excellent in php, c,perl,,linux scripting, apache configuration setting or IT anything. So the company doesn't need to buy the third-party VPN tools or software, just do it by company IT guys
Right ?
Right ?
Expert: Wilder_Admin replied at 2024-07-22 05:57:38
62 points EXCELLENT
Yes that is true. But for sure they can see other sites from that apache or an other webserver. All is depending how it is configured. Thats the reason why some websites have better certificates that the browser shows the adress in a green or red. For example financial sites.
Author: duncanb7 replied at 2024-07-22 05:53:30
Because SSL apache is only for https access means you can download a page to see in your browser. The VPN allows you to connect to networks for example one computer outside the company to the internal lan. So these are two different things. Right?
if users just login the apache server that users just view the server page only or servers information/pages only and could NOT go to other sites from that apache sever site or IP. But on VPN, when users is connected to company local networks, so that they can go through, for example, company server A for finanice(OP:192.122.1.33) and company server B for sales (IP;192.111.1.222) or company server C for marketing(IP:192.122.2.77) in the same company, go to anywhere in local company network if permission is set, Right ?
Expert: Wilder_Admin replied at 2024-07-22 05:52:01
63 points EXCELLENT
That means you will get only access on a web page like on webmail for example. This means you auth yourselfe to get access to the informations what are protected on the website. The communication between your website ls then encrypted more or less on the same way like vpn. The apache is connecting your browser by a ssl encrypted tunnel and transfers the data/informations.
Author: duncanb7 replied at 2024-07-22 05:48:02
And your Auth page on a apache is only access.
Could you write it more int detail about the quotes ?
Expert: Wilder_Admin replied at 2024-07-22 05:47:58
63 points EXCELLENT
Author: duncanb7 replied at 2024-07-22 05:45:35
You mean directly login to my company SSL apache server is not as secure as we get used to login VPN remote software in the past or now, Right ? VPN tunneling is just from the third-party software to help users to transmitt data between networks with high security , right ? Why SSL apache site is not security as VPN access appach ?
Expert: Wilder_Admin replied at 2024-07-22 05:40:51
63 points EXCELLENT
You still have a big missunderstanding about these techniques.
First of all VLAN is a special Method of Subnetting a LAN. What does it means. With that you can organize your Network. For example production and financing. The production is in 192.168.0.0 and the financing is in 192.168.1.0 but all endpoints can communicate with all others with vlan you can define who can talk with whome.
VPN is a tunnel technique. Means all datapackets go through a secure tunnel. This tunnel is encrypted. SO if someone is between he can not see the original packets onls the encrypted ones. Also nobody can see what kind of pakets go trough. Is it mal or web. And your Auth page on a apache is only access.
So all things on your post can be additionally be used and are not alternatives.
