When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-07-22 03:49:06
Point:500 Replies:11 POST_ID:829068USER_ID:11059
Microsoft Visual Basic.Net;Microsoft Excel Spreadsheet Software;Visual Basic Programming
I have three questions
question-1 I am using Excel 2007 VBA to do marco as follows for open FIle Diaglog box
and set the file path at C: emp*.* but it just open the file Diag and *.* is
put at the file inputbox,but I can Not see all file from *.*, Why?
Question-2 What it is different the program filediag code for VBA and VB.NET or Same or
Just smal change ? Could you provide it ?
Question-3 How could I change directory on FileDiag and if using .InitialFileName, it will
show the last slash string in the filename box around bottom of FileDiag box. Why ?
Sub FileDiag() Dim strFileSelected As String Dim objOfficeDialog As Object Dim wbDestination As Workbook Dim wbSource As Workbook Dim sh As Worksheet Dim res As String Application.DisplayAlerts = False Application.EnableEvents = False Application.ScreenUpdating = False Set objOfficeDialog = Application.FileDialog(msoFileDialogFilePicker) Set wbDestination = ActiveWorkbookApplication.FileDialog(msoFileDialogFolderPicker _ ).InitialFileName = "C:Temp*.*" ' res = "Q:DebtInputs" & Format(Date, "yyyy") & "" & Format(Date, "yyyy") & Format(DateAdd("m", -1, Date), "mm") & "Reporting" 'Debug.Print res With objOfficeDialog ' .Title = "Select the Project Cost Allocation file" ' .AllowMultiSelect = False '.InitialFileName = res .ShowEnd With Application.DisplayAlerts = True Application.EnableEvents = True Application.ScreenUpdating = True Exit SubEnd Sub 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:
Author: duncanb7 replied at 2024-07-22 06:22:36
Thanks for all your reply
Expert: CodeCruiser replied at 2024-07-22 06:17:57
100 points EXCELLENT
1) Use the Filters property of the dialog. See example at below link
http://msdn.microsoft.com/en-us/library/office/aa210589(v=office.11).aspx
2) VB.NET is different.
Dim fd As New OpenFileDialog
fd.ShowDialog()
3) Because it wants to :-). That is the property to be used to set the initial path as shown in example on below page
http://msdn.microsoft.com/en-us/library/office/aa210656(v=office.11).aspx
fd.ShowDialog()
Author: duncanb7 replied at 2024-07-22 04:29:54
How about the final question 2, similar code for VB.NET ? it seems similar or same, RIght ?
Expert: gowflow replied at 2024-07-22 04:28:00
I need to logoff now will log in back in 1 to 2 hours. Sorry
gowflow
gowflow
Expert: gowflow replied at 2024-07-22 04:27:14
I do not understand your question. What do you need ?
gowflow
gowflow
Author: duncanb7 replied at 2024-07-22 04:25:14
Sorry for what ?
Expert: gowflow replied at 2024-07-22 04:24:40
Sorry ?
Author: duncanb7 replied at 2024-07-22 04:23:26
Q3 is working at your code
Why you delete code from msoFileDialogFilePicker ?
Expert: gowflow replied at 2024-07-22 04:20:09
400 points EXCELLENT
Oops I can see your code have too many instructions for nothing use this instead:
Sub FileDiag() Dim strFileSelected As String Dim objOfficeDialog As Object Dim wbDestination As Workbook Dim wbSource As Workbook Dim sh As Worksheet Dim res As String Application.DisplayAlerts = False Application.EnableEvents = False Application.ScreenUpdating = False 'Set objOfficeDialog = Application.FileDialog(msoFileDialogFilePicker) Set wbDestination = ActiveWorkbookWith Application.FileDialog(msoFileDialogFilePicker) .InitialFileName = "C:Temp" .Show Application.DisplayAlerts = True Application.EnableEvents = True Application.ScreenUpdating = TrueEnd WithEnd Sub 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:
gowflow
Author: duncanb7 replied at 2024-07-22 04:18:59
what is reply at Q1, and q3 is not working
DUncan
DUncan
Expert: gowflow replied at 2024-07-22 04:17:18
for 1)
to see the files
replace in your code this
by this
for 2) not familiar with vb.net
for 3) simply
replace this
"C:Temp*.*"
by this
"C:Temp"
gowflow
to see the files
by this
for 3) simply
replace this
"C:Temp*.*"
by this
"C:Temp"
gowflow
