When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by mustish1
at 2024-07-21 16:09:41
Point:500 Replies:6 POST_ID:829063USER_ID:11851
PHP Scripting Language;;
Hi guys: Can any one please help me in that syntax error:
Parse error: syntax error, unexpected T_STRING in /home/a7917485/public_html/selentry.php on line 32
Attachment:selentry.php
Author: mustish1 replied at 2024-07-21 17:34:02
Expert: Ray Paseur replied at 2024-07-21 17:12:52
If you want to avoid these kinds of errors in the future, you can try using HEREDOC notation. It provides variable substitution without having to escape all of the quotes marks with those fiddly backslash notations. Amazingly easy, especially when you couple it with PHP object-oriented notation. Heed, but do not be put off by, the warning block.
http://php.net/manual/en/language.types.string.php#language.types.string.syntax.heredoc
Also, there is a character encoding collision in the sample posted here. You might find this article helpful to fix that.
http://www.experts-exchange.com/Web_Development/Web_Languages-Standards/PHP/A_11880-Unicode-PHP-and-Character-Collisions.html
Expert: Gary replied at 2024-07-21 16:33:09
300 points EXCELLENT
This line
$display_block .= "<form method="post" action="".$_SERVER['PHP_SELF'].""><p><label for="sel_id">Select a Record:</label><br/><select id="sel_id" name="sel_id" required="required"><option value="">-- Select One --</option>"; 1:2:3:4:5:
replace with
Notice here
<"select id="sel_id" name="sel_id"
I escaped the "
I escaped the "
Author: mustish1 replied at 2024-07-21 16:28:41
I am sorry I am not understanding what I am mssing
Expert: duncanb7 replied at 2024-07-21 16:19:46
100 points EXCELLENT
There is quotes between quotes for the string
try replace "string"" text" by 'string""text'
Expert: Gary replied at 2024-07-21 16:17:46
You missed escaping a " here
