When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by rav_rav
at 2024-07-21 14:16:57
Point:500 Replies:10 POST_ID:829059USER_ID:11962
Hi Experts,
I have a table with, for example, names of sales staff in Column A. Column B, C, D.... represent calendar days and the sales that each staff made on a given calendar day.
I'd like to write a formula on a separate worksheet that calculates the sales when the user enters:
Input Variables
B1 (Sales Rep Name): Jane Doe
B2 (Start Date): 01/01/2014
B3 (End Date): 01/15/2014
Output on cell C1 should be Jane Doe's sales from 01/01/2014 - 01/15/2014
Input Variables
Expert: Glenn Ray replied at 2024-07-27 22:02:25
Rav...I was still trying to work that out. I don't think our comments merit a solution just yet.
I was able to partially solve the problem using an array function like so:
=SUMPRODUCT(--(COLUMN('Raw Data'!B1:E1)>=$C$2)*--(COLUMN('Raw Data'!B1:E1)<=$C$3),{1770,6000,1770,2401})
This is not an array function, but it does contain an array of values at the end that represent all sales for Jane Doe for all dates listed. The formula properly gets only those values for the corresponding start and end dates selected. However, I have not been able to figure out how to add a function to create all possible total values for any individual and replace the array in there now. That's where I'm stuck.
-Glenn
-Glenn
Author: rav_rav replied at 2024-07-27 14:18:28
Hi Glenn, Rob,
Thanks for your help.
Glenn: Out of curiousity, what would the complex array formula look like?
Ravi
Ravi
Expert: Rob Henson replied at 2024-07-23 04:54:13
250 points GOOD
Hmm, looks like a Table cannot have True Dates as headers, they keep getting converted to text even when overwritten.
If you convert the Table to a Data Range, and convert dates to true dates, the above works.
Rob H
Rob H
Expert: Rob Henson replied at 2024-07-23 04:30:14
On the Raw Data tab, are you averse to using a helper column? If not, in a spare column use the following formula:
=IF($A2=Output!$B$1,SUMIFS($B2:$E2,$B$1:$E$1,">="&Output!$B$2,$B$1:$E$1,"<="&Output!$B$3),0)
This looks at the name in column A and compares it to the Output tab name. If not the same it gives zero otherwise it adds up the row for the dates in the range on the Output Tab.
I have put this in cell H2 but as you say you could have up to 120 columns it would be much further to the right; adjust the ranges B:E to accomodate the required column.
Your formula on the Output tab can now just be a sum of the helper column, ie =SUM('Raw Data'!H:H)
At the moment this is giving zero value for me but the issue is because the date headers in the Raw Data are text rather than true dates.
Rob H
Rob H
Expert: Glenn Ray replied at 2024-07-22 09:48:30
250 points GOOD
You can use up to 127 criteria in a SUMIFS statement, but you wouldn't be able to use it with the table layout you described since the date information isn't included in each row of data. This is just one reason why this is not a good data table layout. Transactional data like this should be timestamped; this layout allows for a lot of null values (ex., dates where no sales occur for a given individual).
Will probably need a complex array formula to resolve this, unless you're willing to transpose your original data.
Author: rav_rav replied at 2024-07-22 05:25:32
Hi All,
Sorry for the confusion. I've modified Glenn Ray's file to show how my table actually looks like. I have dates sequential dates in the column headers and the sales amounts in the table cells. In real life, I have about 120 calendar days currently, so 120 columns.
How would the SUMIF / SUMIFS formulas be changed to give the desired results?
Many Thanks
Many Thanks
Expert: Glenn Ray replied at 2024-07-21 22:50:11
You can accomplish this with a SUMIFS function, assuming you're using Excel 2010/2013 (based on your previous questions).
I've created an example file that demonstrates this. The sales data is in a table on Sheet1; the data entry cells and resultant SUMIFS function are on Sheet2. The SUMIFS function is as follows:
=SUMIFS(Sheet1!D:D,Sheet1!A:A,B1,Sheet1!B:B,">="&B2,Sheet1!C:C,"<="& B3)
One thing that isn't clear from your description - except for the salesperson name in column A - is exactly what each column in your sales data represents. I assumed:
A - Salesperson name
B - Sales Date
C - some other date (not taken into account in this example)
D - Sales Amount
Please clarify if the additional date (if it exists) is indeed relevant and how it needs to be measured.
Regards,
-Glenn
B - Sales Date
D - Sales Amount
Regards,
-Glenn
Expert: Rgonzo1971 replied at 2024-07-21 22:45:40
And if you do not have SUMIFS
pls try
=SUM((Sheet1!D2:D1000)*(Sheet1!A2:A1000=B1)*(Sheet1!B2:B1000>=B2)*(Sheet1!C2:C1000<=B3))
as an array Formula Enter with Ctrl-Shift-Enter
Regards
pls try
Regards
Expert: Rgonzo1971 replied at 2024-07-21 22:38:12
pls try
=SUMIFS(Sheet1!D:D,Sheet1!A:A;B1,Sheet1!B:B,">="&B2;Sheet1!C:C,"<="&B3)
Regards
pls try
Regards
Expert: duncanb7 replied at 2024-07-21 15:14:45
at C1 cell , you try, and those data is from B1, B2, B3
=TRIM(MID(B1,FIND(":",B1)+1,100))&"'s sales from "&TRIM(MID(B2,FIND(":",B2)+1,100))& " - " &TRIM(MID(B3,FIND(":",B3)+1,100))
Output on cell C1 is Jane Doe's sales from 01/01/2014 - 01/15/2014
