When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by pma111
at 2024-07-20 13:54:58
Point:500 Replies:5 POST_ID:829043USER_ID:10
Miscellaneous Databases;;MS SQL Server
What are the risks in storing the db and logfiles on the same drive.
If its purely performance risk... why doea storing both on the same drive cause performance issues.
Expert: duncanb7 replied at 2024-07-30 10:28:42
Thx for your pt
ve a nice day
ve a nice day
Expert: Qlemo replied at 2024-07-21 09:45:55
Of course. I forgot that reading logfiles happens in memory most of the time, different from starting MSSQL.
In addition to that, logfile writes may not be buffered (need to be write-thru), and the DBMS usually forces that (MSSQL does).
Expert: ScottPletcher replied at 2024-07-21 09:31:26
166 points EXCELLENT
>> While logfile operations tend to be more sequential and equally read/write <<
Log file operations are overwhelmingly write, not an equal mix of read and write. That is why RAID5 is not a good choice for log files.
Expert: Qlemo replied at 2024-07-20 14:29:37
167 points EXCELLENT
Both reliability and performance are the reason for separating.
It does not make sense to use two partitions on the same physical disk - if it fails, both partitions are bad, and all files lost. For reliability you try to have a datafile backup and logfiles or a datafile and logfile backups available all the time.
More, neither DBMS I/O subsystem nor the OS I/O subsystem can optimize access for different partitions as good as for a single one. In general, the drive heads have to move much more in such cases.
With DBMS datafiles and logfiles use different access methods. While logfile operations tend to be more sequential and equally read/write, datafiles are read and written in a more random manner, with usually much more reads than writes.
It makes sense to use a file system adapted to those needs - and that is a different one for each.
Using RAID with redundancy (10 or 5 or similar) lessens the importance of separating files. On a RAID 10 you can place both file types into the same file system without risking performance or reliability (to a certain extend).
Expert: duncanb7 replied at 2024-07-20 14:04:44
Database recovery is concern.
Seperate it that is better and same drive Risks reported at this site
http://support.microsoft.com/kb/2033523
and you can take a look at relative link for reference only if have time at
http://technet.microsoft.com/en-us/library/aa996891(v=exchg.80).aspx
