When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by lineonecorp
at 2024-07-20 13:18:37
Point:500 Replies:10 POST_ID:829040USER_ID:11943
Outlook Groupware Software;;Powershell
I have a bunch of individual PST's - is there a scripted way to merge them into a single PST e.g. with Powershell? Please not I do not want any 'manual' solutions.
Author: lineonecorp replied at 2024-07-29 01:26:45
Perfect. Thanks.
Expert: thims replied at 2024-07-28 03:31:48
Yes. It would be something like this:
@echo offset CLI=C:Program Files (x86)ReliefJet EssentialsExecutorCli.exeset TARGET=D:Testset PROFILE=Outlook"%CLI%" /p Profile="%PROFILE%" /u OutlookStorageCreate TargetFile="%TARGET%PSTMerged.pst"for %%f in (*.pst) do ( "%CLI%" /p Profile="%PROFILE%" /p File="%%f" /u OutlookStorageMerge For=* Target=\PSTMerged)"%CLI%" /p Profile="%PROFILE%" /u OutlookStorageCreate TargetFile="%TARGET%PSTMerged.pst" Detach=True 1:2:3:4:5:6:7:8:9:10:
Edit CLI, TARGET and PROFILE variables (CLI = path to ReliefJet's ExecutorCli.exe, TARGET = path to destination folder, PROFILE = Outlook profile name). Then put this code in, say, Merge.bat file, put this file in folder that contains your pst1.pst, pst2.pst, .... and run it from there.
This batch creates (or opens) %TARGET%PSTMerge.pst file, merges all *.pst in the current folder into PSTMerge.pst and then detaches PSTMerge from your Outlook profile.
Author: lineonecorp replied at 2024-07-26 19:55:46
Thanks. The batch file I take it would be from Reliefjets?
Expert: thims replied at 2024-07-25 00:35:01
Sure. You can have a batch file that will do it automatically.
Author: lineonecorp replied at 2024-07-24 14:02:26
Thanks for jumping on this. I will give it a gander. Quick question - try before I try before I buy: will this allow batching? In other words I point to a folder of PST's - PSTfolder which has in it: pst1, pst2,pst3 -and I say 'Merge' and voila they are merged into PSTmerged.
Expert: thims replied at 2024-07-23 13:50:08
I'm one of the developers. You can download the trial and try before buy. You can merge Outlook storages (including PST files) or merge Outlook folders. There are tools for splitting, exporting to PST and many more (over 90 utilities) included.
Here is the example of the command line:
ExecutorCli.exe /p Profile="Outlook" /u OutlookStorageMerge For=\SourceStorage Target=\TargetStorage 1:
where "Outlook" is the name of your Outlook profile, SourceStorage and TargetStorage are paths to the required storages. The product provides a GUI tool that constructs command lines automatically.
Moreover, you can contact support and we'll provide you with ready-to-run scripts for your particular needs free of charge.
Author: lineonecorp replied at 2024-07-23 12:48:15
Thanks. However I don't see any reference to merging PST's. Have you used it for that purpose? If so what command/script did you use? It's not practical for me to buy the product or spend time on it unless I know for sure it can do what I want.
Expert: thims replied at 2024-07-23 07:42:42
There is a commercial tool: ReliefJet Essentials. Professional Edition provides command line that can be easily utilized to merge PST files or any other Outlook storages/mailboxes.
Author: lineonecorp replied at 2024-07-20 19:46:06
Thanks. I looked over this but I'm not sure that this is exactly what I am looking for. I don't want to import or export. I have two or more PST's and I want to merge them into one - stick them into a folder somewhere, run a script and voila I have one PST file.
For instance a folder contains monday.pst, tuesday.pst and wednesday.pst. I run my script and now the folder contains combined.pst which is monday.pst, tuesday.pst and wednesday.pts combined into one big PST.
Expert: duncanb7 replied at 2024-07-20 13:25:02
Take a look at this link that using PowerShell to merge PST file without using third party software
https://www.simple-talk.com/sysadmin/exchange/importing-psts-with-powershell-in-exchange-2010-sp1/
