When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-07-20 08:37:30
Point:500 Replies:14 POST_ID:829036USER_ID:11059
Web Browsers;;Cascading Style Sheets (CSS)
When I answer CSS question on EE, I will first look into author's webpage and look
into the issue view point location such as submenu under menu that is similar to
the issue at this EE thread link
http://www.experts-exchange.com/Web_Development/Web_Languages-Standards/CSS/Q_28479835.html
When I answer the question, I will go to firefox developer tool and use "Inspect element"
to find out the exact issue location, and I could not find out the exact CSS file or CSS location. So, I need to view page source to find out or guess where the issue CSS location is
that is really slow to answer the question.
My question is that How can I find the exact CSS issue location code quickly on
Firefox or Chrome browser developer tools ?
Why I will use using "Inspect element" on FF developer tool can Not locate the exact
CSS code on such issue tag when mouse hover on the issue spot on the webpage
Or there is other way to find out CSS issue code on such tag quickly ?
What tools besides experts experience can answer the question as fast as it did
in the previous link.
Author: duncanb7 replied at 2024-07-20 09:29:18
Thanks for your reply, I'll work around for firebug
Expert: Gary replied at 2024-07-20 09:28:10
I think so, easier to do things in Firebug
Author: duncanb7 replied at 2024-07-20 09:27:14
Last post, Firebug is better than FF developer tools , Right ?
Expert: Gary replied at 2024-07-20 09:25:16
I only use Firebug
https://getfirebug.com/wiki/index.php/Main_Page
And sometimes HTTPFox
https://addons.mozilla.org/en-US/firefox/addon/httpfox/
Author: duncanb7 replied at 2024-07-20 09:19:57
Do you have any good FF developer tools manual or site information ?
Expert: Gary replied at 2024-07-20 09:18:10
There's no special secret to it, just inspect the element and work back or forth til you find the relevant element css that needs to be fixed.
There is no one way fits all since every website is different, it's a case of practise makes perfect when you just know what is wrong
Author: duncanb7 replied at 2024-07-20 09:17:56
And that is why I seldom or rarly answer CSS question in EE
Author: duncanb7 replied at 2024-07-20 09:16:25
Any external FF site or tools on internet for developer about my issue, please advise
Expert: Gary replied at 2024-07-20 09:15:43
It's not an :hover issue, the image zoom container is higher in the z-index.
Author: duncanb7 replied at 2024-07-20 09:15:13
If you can provide small your search practice instruction to search CSS issue location on FF developer tools that will be really good
Author: duncanb7 replied at 2024-07-20 09:11:49
I mouse right-click to :hover on the each tag code on issue html code as follows, but could not find out the issue CSS code. Why ?
<section class="row row-3"><section class="column column-1 grid-left-0 grid-width-24"><nav id="block-b5753b9edabd8c29" class="Mainmenu block block-type-navigation block-fluid-height" data-alias="Main Menu"itemscope="" itemtype="http://schema.org/SiteNavigationElement"><div class="block-content"><div class="nav-horizontal nav-align-center"><ul id="menu-menu-1" class="menu"><li class="menu-item menu-item-type-post_type menu-item-object-page menu-item-177"><a href="http://www.shopsmook.com/whats-new/">What’s New</a></li><li class="menu-item menu-item-type-post_type menu-item-object-page menu-item-has-children current_page_parent menu-item-186"><a href="http://www.shopsmook.com/shop/">CLOTHES</a><ul class="sub-menu"> <li class="menu-item menu-item-type-post_type menu-item-object-page menu-item-179"><a href="http://www.shopsmook.com/man/">MAN</a></li> <li class="menu-item menu-item-type-post_type menu-item-object-page menu-item-178"><a href="http://www.shopsmook.com/woman/">WOMAN</a></li></ul></li><li class="menu-item menu-item-type-post_type menu-item-object-page menu-item-182"><a href="http://www.shopsmook.com/shoes/">SHOES</a></li><li class="menu-item menu-item-type-post_type menu-item-object-page menu-item-181"><a href="http://www.shopsmook.com/accesories/">Accesories</a></li><li class="menu-item menu-item-type-post_type menu-item-object-page menu-item-180"><a href="http://www.shopsmook.com/vintage/">Vintage</a></li><li class="menu-item menu-item-type-post_type menu-item-object-page menu-item-184"><a href="http://www.shopsmook.com/sale/">SALE</a></li><li class="menu-item menu-item-type-post_type menu-item-object-page menu-item-183"><a href="http://www.shopsmook.com/lookbooks/">LOOKBOOKS</a></li><li class="menu-item menu-item-type-post_type menu-item-object-page menu-item-185"><a href="http://www.shopsmook.com/blog/">BLOG</a></li></ul></div><!-- .nav-horizontal nav-align-center --></div><!-- .block-content --></nav><!-- #block-b5753b9edabd8c29 --></section><!-- .column --></section><!-- .row --> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:
Expert: Gary replied at 2024-07-20 09:11:07
That's because the image doesn't really exist where it is, right click the image when you get the zoom happening and inspect element and then move up the node tree to get the container.
Author: duncanb7 replied at 2024-07-20 09:05:35
Change the z-index on the .yith_magnifier_zoom_wrap {...} class to 1
/assets/css/yith_magnifier.css
The answer from your thread, I could Not find the location . Where is it at which tag ?
I could Not see the CSS code even I tried mourse right-click to the code page under the
webpage
Expert: Gary replied at 2024-07-20 08:45:48
When using Firebug, select the element, click the Style tab dropdown arrow and click hove/active/focus and that will show the css for the various states
Don't think you can do that with the native Element Inspector in FF
