When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by PeppeLaPew
at 2024-07-20 06:23:42
Point:500 Replies:8 POST_ID:829034USER_ID:11937
Wireless Technologies;;Network Analysis Software
I have a client who would like to monitor web activity. The network he wants to monitor is a guest WiFi network, on a completely separate ISP than their corporate network.
The Wifi access point is an ISP provided router, and does not appear to have any logging capabilities.
I am open to both hardware/software suggestions.... the only caveat, it has to be easy.
Having tested several options (WireShark, and several other less well known) none have the capability to provide him a simple read out of activity. Everything appears to require an IT guy to interpret the output, or a secondary program to analyze the data.
Does anyone know a product that will give him a simple read out for web activity?
Expert: John Hurst replied at 2024-08-09 07:38:51
@PeppeLaPew - Thanks for the update. I have used Whats Up where the client was willing to entertain the cost, but they got what they wanted.
Author: PeppeLaPew replied at 2024-08-09 07:35:08
Whats Up would have probably have been a more complete solution than the OpenDNS, so you get the points.
Sometimes those $$ make a client settle for less than a complete solution
Author: PeppeLaPew replied at 2024-08-09 07:33:06
Sorry for the delay.... What's up would work, but was too expensive of a solution for my client.
Changed the routers DNS servers to Open DNS
Opened an account on open DNS with his external IP.
Turned on logging.
Now the client can see WiFi traffic (at least DNS requests) and block web sites at a global level.
Unfortunately its not able to tell him which computer generated the request, but it's free.
Thanks all!
Turned on logging.
Thanks all!
Expert: John Hurst replied at 2024-07-22 05:23:25
Try What's Up.
Author: PeppeLaPew replied at 2024-07-22 05:18:16
What you mean , "read out for web activity" ?
You can save all activity in cap file or save it in csv format
Could you explain it in more detail ? Probably, wireshark is really popular
By read out.... I mean the information as it is displayed to the user. The information displayed by wireshark requires a person with some technical ability to Comprehend/Filter/Analyze.
He needs a program/router/something that will give him a easy to read report.
Something like:
These are the devices detected, these are the web requests from that device, this many times, on these dates.
Something like:
Expert: nickoarg replied at 2024-07-21 06:37:13
You can also try using a transparent proxy such as Squid that will log the requests. Most users will not know the proxy is there.
Expert: John Hurst replied at 2024-07-20 08:09:19
I use CommView and (like Wireshark) the simple tools are packet sniffing tools and are not user oriented.
For an easy, user-oriented, GUI reporting tool, you need What's Up by Ipswitch.
http://www.whatsupgold.com/
Expert: duncanb7 replied at 2024-07-20 07:46:57
Dunca
Dunca
