When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Michael_Leng
at 2024-07-18 18:11:33
Point:500 Replies:6 POST_ID:829026USER_ID:11899
Windows Batch Scripting;Windows XP Operating System;Scripting Languages
Hi All Experts,
I need to use batch file to implement the following points
1/. user computer must be screen saver with password protected.
2/. screen saver time out value = 300seconds (5minutes)
3/. user can not change screen saver or the screen saver time out value.
when I run the batch file, it will implement those policy.
so please help.
so please help.
Expert: sirbounty replied at 2024-07-18 20:12:19
Regini is the utility I was thinking of for the permissions change (http://support.microsoft.com/kb/264584), but I can't stress enough that this isn't the approach you want to use to handle this scenario... This is why policies were created. :^)
Expert: sirbounty replied at 2024-07-18 20:09:57
167 points EXCELLENT
Sure, a batch file will set the values you requested:
reg add "hkcucontrol paneldesktop" /v screensaverissecure /d 1
reg add "hkcucontrol paneldesktop" /v ScreenSaveTimeOut /d 300
But to prevent the user from changing their "user" settings goes against the design. You can only lock them down via policy, unless you're also going to manipulate the permissions on the desktop key, which is highly advised against. Though even if you would go that route, it would mean a separate instance because that could only be changed by an admin...
Author: Michael_Leng replied at 2024-07-18 19:53:08
I am in a Domain environment. anyways I prefer to run the batch file or script on each client computer instead of using group policy, as i want to exclude some client, so is it possible?
I think it is much easier.
thanks
thanks
Expert: duncanb7 replied at 2024-07-18 19:25:16
Be Reminded window XP is no longer supported by Microsoft.
You can do this, set all setting for screen saver on window as adminstrator
and then change the registry key to hide those setting from user
from the tools such as http://www.pctools.com/guides/registry/detail/170/
For group policy, I am NOT quite sure doing Group policy on XP easier or more time-consuming than on window 7
(Note: The following link is just for your reference at option2- and option-3 ,how to solve your similar issue on window 7 but not on xp, http://www.sevenforums.com/tutorials/15322-screen-saver-password-protection-enable-disable.html)
Expert: Mitchell Milligan replied at 2024-07-18 18:41:52
166 points EXCELLENT
Group Policy would be the best way to handle this, even if you are not in a domain environment. You can edit the local security policy to enact those changes.
Expert: sirbounty replied at 2024-07-18 18:35:13
Are you in a domain environment or not?
You can do this with a mandatory policy... http://support.microsoft.com/kb/307800
