When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by fh_freese
at 2024-07-18 17:55:58
Point:500 Replies:5 POST_ID:829025USER_ID:11849
Expert,
In automating this workbook for the client, I've been ask to populate formulas from the attached worksheet to other cells in the same workbook labeled "Consolidated". The range to be populated in the "Consolidated" worksheet would be C6:U17. For example, in cell C6 the formula needs to be ''Jan 14'!B37, cell D6= 'Jan 14'!C37, cell E6 = 'Jan 14'!D37. This is the pattern for each month.
Currently, they have 15 Projects for 2014. Next year, they may want to add another year in the same work book and update the formulas in the Consolidated worksheet. Adding the next year worksheet with the correct tabs labeled has been solved. If I can get a macro that updates the months in the Consolidated for the first year as attached I know I can use that for upcoming year(s).
If I'm unclear, please advise. Thanks to all.
Attachment:Consolidaed-with-Formulas.xlsm
Author: fh_freese replied at 2024-07-18 19:03:09
thank you
Author: fh_freese replied at 2024-07-18 18:51:57
That's exactly what I'm working on now.
Expert: duncanb7 replied at 2024-07-18 18:46:39
Just start small example first for 1 or 2 times Excell cell operation, and then get the recoded VBA code that will help to start your code writing easily and that also help other experts to assist your to finish your 228 time target or complete issue if you can provide some preparation work vba code, that also help on communication easily and fast during question reply and answer on this thread.
If the 1 or 2 times operation is similar to 224, you just change those variables setting
on the recorded VBA macro, for example,I think next time you will ask how to
program the workbook name as variable on VBA, that will help to narrow down the
issue and reduce your project time.
Author: fh_freese replied at 2024-07-18 18:26:21
I have thought of that but that would mean 228 times. However, maybe just doing three or four I could then adjust the code for the complete macro...
Expert: duncanb7 replied at 2024-07-18 18:05:03
Could you do it in manually ? If so, using Excel "Record macro" function to record all
your action that you did previously and manually. The macro recording function
will save all your action into one macro, and then you can copy the VBA code from
the macro for your reference to start your VBA macro program or writing.
It is video for Excel recording macro tutorial at
http://www.youtube.com/watch?v=nvWpFdo7EO0
