When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by t1shopper
at 2024-07-18 14:30:34
Point:500 Replies:14 POST_ID:829023USER_ID:11928
Linux;Linux Network Security;Linux Programming
How do I fix this?
SELinux is preventing tzdata-update (tzdata_t) "unlink" to localtime (etc_t).Detailed Description:SELinux is preventing tzdata-update (tzdata_t) "unlink" to localtime (etc_t).The SELinux type etc_t, is a generic type for all files in the directory andvery few processes (SELinux Domains) are allowed to write to this SELinux type.This type of denial usual indicates a mislabeled file. By default a file createdin a directory has the gets the context of the parent directory, but SELinuxpolicy has rules about the creation of directories, that say if a processrunning in one SELinux Domain (D1) creates a file in a directory with aparticular SELinux File Context (F1) the file gets a different File Context(F2). The policy usually allows the SELinux Domain (D1) the ability to write,unlink, and append on (F2). But if for some reason a file (localtime) wascreated with the wrong context, this domain will be denied. The usual solutionto this problem is to reset the file context on the target file, restorecon -v'localtime'. If the file context does not change from etc_t, then this isprobably a bug in policy. Please file a bug report(http://bugzilla.redhat.com/bugzilla/enter_bug.cgi) against the selinux-policypackage. If it does change, you can try your application again to see if itworks. The file context could have been mislabeled by editing the file or movingthe file from a different directory, if the file keeps getting mislabeled, checkthe init scripts to see if they are doing something to mislabel the file.Allowing Access:You can attempt to fix file context by executing restorecon -v 'localtime'The following command will allow this access:restorecon 'localtime'Additional Information:Source Context root:system_r:tzdata_t:SystemLow-SystemHighTarget Context root:object_r:etc_tTarget Objects localtime [ lnk_file ]Source tzdata-updateSource Path /usr/sbin/tzdata-updatePort <Unknown>Host <Unknown>Source RPM Packages glibc-common-2.5-118.el5_10.2Target RPM PackagesPolicy RPM selinux-policy-2.4.6-346.el5Selinux Enabled TruePolicy Type targetedMLS Enabled TrueEnforcing Mode EnforcingPlugin Name mislabeled_fileHost Name www.t1shopper.comPlatform Linux www.t1shopper.com 2.6.18-371.8.1.el5 #1 SMP Thu Apr 24 18:19:36 EDT 2014 x86_64 x86_64Alert Count 1First Seen Fri Jul 18 21:16:23 2014Last Seen Fri Jul 18 21:16:23 2014Local ID 7c273cdf-e822-48f4-90a3-2e13b6e1996eLine Numbers 16744, 16745Raw Audit Messagestype=AVC msg=audit(1405718183.87:560873): avc: denied { unlink } for pid=2777 comm="tzdata-update" name="localtime" dev=dm-0 ino=29262001 scontext=root:system_r:tzdata_t:s0-s0:c0.c1023 tcontext=root:object_r:etc_t:s0 tclass=lnk_filetype=SYSCALL msg=audit(1405718183.87:560873): arch=c000003e syscall=82 success=no exit=-13 a0=7fff66233ca0 a1=400cf9 a2=76 a3=6094e0 items=0 ppid=29416 pid=2777 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=pts1 ses=92051 comm="tzdata-update" exe="/usr/sbin/tzdata-update" subj=root:system_r:tzdata_t:s0-s0:c0.c1023 key=(null) 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:43:44:45:46:47:48:49:50:51:52:53:54:55:56:57:58:59:60:61:62:63:64:
Expert: Sandy replied at 2024-07-24 21:17:55
Seems like yes.. check and suggest
ty/sa
ty/sa
Author: t1shopper replied at 2024-07-24 21:14:47
That all seemed to run successfully (see below). Should it be fixed?
[root@www ~]# cd /etc/[root@www etc]# restorecon -R /etc 'localtime'[root@www etc]# ls -lZ localtimelrwxrwxrwx root root root:object_r:etc_t localtime -> /usr/share/zoneinfo/GMT[root@www etc]# 1:2:3:4:5:
Expert: Sandy replied at 2024-07-24 20:37:49
hold on... you execute the correct command from wrong path
#cd /etc/
#ls -lZ localtime
Now check and post...
TY/SA
#cd /etc/
#ls -lZ localtime
TY/SA
Author: t1shopper replied at 2024-07-24 10:48:38
I'm not sure if any of this fixed it but here's the status:
- Sandy: The output of your solution is included below.
- Duncanb7: Here's the output if the 4 tests.
[root@www ~]# restorecon -v 'localtime'lstat(localtime) failed: No such file or directory[root@www ~]# restorcon 'localtme'-bash: restorcon: command not found[root@www ~]# restorecon 'localtme'lstat(localtme) failed: No such file or directory[root@www ~]# restorecon 'localtime'lstat(localtime) failed: No such file or directory[root@www ~]# restorecon -R -v /etc 'localtime'restorecon reset /etc/aliases context root:object_r:etc_t:s0->system_u:object_r:etc_aliases_t:s0restorecon reset /etc/dovecot.conf context root:object_r:etc_t:s0->system_u:object_r:dovecot_etc_t:s0restorecon reset /etc/rc.d/init.d/php_mysql_memory_table_maxmind context root:object_r:etc_t:s0->system_u:object_r:initrc_exec_t:s0restorecon reset /etc/my.cnf context root:object_r:etc_t:s0->system_u:object_r:mysqld_etc_t:s0restorecon reset /etc/modprobe.d/anaconda.conf context system_u:object_r:file_t:s0->system_u:object_r:etc_t:s0restorecon reset /etc/aliases.original context system_u:object_r:etc_aliases_t:s0->system_u:object_r:etc_t:s0restorecon reset /etc/openwsman/serverkey.pem context system_u:object_r:etc_runtime_t:s0->system_u:object_r:etc_t:s0restorecon reset /etc/openwsman/servercert.pem context system_u:object_r:etc_runtime_t:s0->system_u:object_r:etc_t:s0restorecon reset /etc/sysconfig/mkinitrd/multipath context system_u:object_r:file_t:s0->system_u:object_r:etc_t:s0restorecon reset /etc/sysconfig/iptables.2012-03-01.default.original context root:object_r:etc_t:s0->system_u:object_r:iptables_conf_t:s0restorecon reset /etc/sysconfig/iptables.2013-02-13 context root:object_r:etc_runtime_t:s0->system_u:object_r:iptables_conf_t:s0restorecon reset /etc/sysconfig/iptables.2011-01-10 context root:object_r:etc_t:s0->system_u:object_r:iptables_conf_t:s0restorecon reset /etc/sysconfig/iptables_base_configuration context root:object_r:etc_t:s0->system_u:object_r:iptables_conf_t:s0restorecon reset /etc/sysconfig/iptables context root:object_r:etc_t:s0->system_u:object_r:iptables_conf_t:s0restorecon reset /etc/sysconfig/ip6tables context root:object_r:etc_t:s0->system_u:object_r:iptables_conf_t:s0restorecon reset /etc/sysconfig/iptables.2013-04-20 context root:object_r:etc_t:s0->system_u:object_r:iptables_conf_t:s0restorecon reset /etc/sysconfig/iptables.2013-08-31 context root:object_r:etc_t:s0->system_u:object_r:iptables_conf_t:s0restorecon reset /etc/sysconfig/iptables-config context root:object_r:etc_t:s0->system_u:object_r:iptables_conf_t:s0restorecon reset /etc/my.cnf.2013-03-01.original context system_u:object_r:mysqld_etc_t:s0->system_u:object_r:etc_t:s0restorecon: error while labeling files under localtime[root@www ~]# restorecon -R /etc 'localtime'restorecon: error while labeling files under localtime 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:
Expert: duncanb7 replied at 2024-07-19 01:56:56
sandy reminds me, thanks, Sorry, tishopper question post that it mentioned
Allowing Access:
So try
- TEST-1, restorecon -v 'localtime'
-TEST-2, restorcon 'localtme'
-Test-3, restorecon -R -v /etc 'localtime'
-TEst-4, restorecon -R /etc 'localtime'
Probably it will work hopefully
Allowing Access:
So try
Expert: Sandy replied at 2024-07-19 01:46:20
Restorecon -R /etc localtime
Author: t1shopper replied at 2024-07-18 20:05:44
Is this what you want? If not, please give me exact commands to run. Thanks.
drwxr-xr-x root root system_u:object_r:etc_t etcdrwxr-xr-x root root system_u:object_r:locale_t zoneinfo 1:2:3:
Expert: duncanb7 replied at 2024-07-18 19:03:12
could you check the file or directory permisision privilege or right on that file /etc/localtime or its link file or directory ?
Author: t1shopper replied at 2024-07-18 16:55:17
No change in permissions or context.
[root@www ~]# sudo restorecon -v '/etc/localtime'[root@www ~]# ls -Z /etc/localtimelrwxrwxrwx root root root:object_r:etc_t /etc/localtime -> /usr/share/zoneinfo/GMT[root@www ~]sudo restorecon -v '/usr/share/zoneinfo/GMT'[root@www ~]# ls -Z '/usr/share/zoneinfo/GMT'-rw-r--r-- root root system_u:object_r:locale_t /usr/share/zoneinfo/GMT 1:2:3:4:5:6:7:
Expert: duncanb7 replied at 2024-07-18 16:30:03
how about sudo ?
Author: t1shopper replied at 2024-07-18 16:24:39
You are already in root access, why it will have issue ?
I don't know, that's what I'm asking you! Expert: duncanb7 replied at 2024-07-18 16:22:58
You are already in root access, why it will have issue ? could you do sudo with the command ?
Author: t1shopper replied at 2024-07-18 16:15:18
What command or utility tool recently you ran so that you have such issue ?
Probably when the system ran yum update it tried to update the timezone files.Here's the steps I took to fix it which didn't seem to work because the security settings on the file didn't change.
[root@www ~]# ls -Z /etc/localtimelrwxrwxrwx root root root:object_r:etc_t /etc/localtime -> /usr/share/zoneinfo/GMT[root@www ~]# restorecon '/etc/localtime'[root@www ~]# restorecon -v 'localtime'lstat(localtime) failed: No such file or directory[root@www ~]# ls -Z /etc/localtimelrwxrwxrwx root root root:object_r:etc_t /etc/localtime -> /usr/share/zoneinfo/GMT[root@www ~]# ls -Z /usr/share/zoneinfo/GMT-rw-r--r-- root root system_u:object_r:locale_t /usr/share/zoneinfo/GMT 1:2:3:4:5:6:7:8:9:10:11:12:
Expert: duncanb7 replied at 2024-07-18 14:45:55
The attachment you posted said try to
And it suggests to use restorecon '/etc/localtime' in this blog that is similar to your issue at
https://bugzilla.redhat.com/show_bug.cgi?id=517452
