When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by frankbustos
at 2024-07-18 14:17:20
Point:500 Replies:11 POST_ID:829022USER_ID:11927
iPhone;;
hi experts,
i have an iphone 5 and the battery is not lasting long at all. I charge it to 100% and 30min later it's at 60%, it doesn't even last 2hours and I don't have any applications open! What can be causing this?
Expert: John Hurst replied at 2024-07-25 17:50:30
@frankbustos - Thanks for the update and I was happy to help.
Author: frankbustos replied at 2024-07-25 15:49:36
resetting wireless worked. thanks!
Expert: Geisrud replied at 2024-07-22 09:36:13
I've seen battery improvement after a simple phone reboot (a symptom you might notice is the phone is often unusually warm, even without much use).
To reboot, hold the Home button and Standby button until you see the Apple Logo, then release.
Expert: Sikhumbuzo Ntsada replied at 2024-07-20 22:35:51
Is it jailbroken?
Expert: John Hurst replied at 2024-07-18 15:30:47
The link itself was not content-free, but there was no proposed solution. Without the link, the post would not have helped much or at all. That is our test. The rest of the posts are posting actual ideas. Thanks.
Expert: magarity replied at 2024-07-18 15:27:18
duncanb's link to that zdnet article was not content-free; the content was in the picture slideshow, not the text.
Expert: John Hurst replied at 2024-07-18 15:03:24
@frankbustos - Another thing that can help is to reset all your wireless and cellular connections (from the Settings Icon). I found my machine getting warm and chewing up battery when I returned from overseas recently. Resetting the connections helped. I had to remake the connections but no data lost at all.
Expert: John Hurst replied at 2024-07-18 14:47:48
duncanb - your post was essentially a content-free link. Please post solutions in your own words in future.
A reminder to everyone about blind links :
http://support.experts-exchange.com/customer/portal/articles/1162518
Thank you, Thinkpads_User, Topic Advisor
Expert: John Hurst replied at 2024-07-18 14:46:03
One thing that works well on my iPhone 4s is to change email from push (always checking) to check manually (on request) or every half hour (and you can still check manually).
I went from 3 hours to most all day.
Expert: Alan Hardisty replied at 2024-07-18 14:45:53
If you charge it fully and let it discharge fully so that it turns off before recharging it, does it hold its charge for longer?
Have you backed up your phone, reset it and reinstalled the latest iOS via a PC? If not, I would recommend it.
Turn off all unwanted background applications as they can drain the battery Settings> General> Background App Refresh.
Have you got any Exchange Activesync accounts setup on the phone? If you have, set the sync to manual not Push and don't check your mail - does that improve life?
Alan
Alan
Expert: duncanb7 replied at 2024-07-18 14:33:45
it is hard to find out exact root cause. it prefer to reduce power consumption for whole system improvement
Take a look at this
http://www.zdnet.com/how-to-improve-your-iphones-battery-life-updated-for-ios7-7000014902/
Take a look at this
