When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-07-18 08:37:29
Point:500 Replies:3 POST_ID:829018USER_ID:11059
Network Analysis Software;Network Operations;Networking Protocols
I have been using wireshare,fiddler,charles, Microsoft Network Monitor to
monitor my computer network traffic or proxy http debugging.
One question I would like to know how I can check my internet
connectivity that I could be aware of where my computer is connected
or disconnect to the internet or my ISP.
I have checked, Microsoft window will check the connection and put it in the registry on window
http://www.techrepublic.com/blog/data-center/what-do-microsoft-and-ncsi-have-in-common/
I try it on wireshare by capture filter such as dns.qry.name==dns.msftncsi.com
but nothing filter out, Why ?
I don't want to create batch script for running ping command periodically in every one minute
to check the connectivity since I think that is not in good way.
If wireshare could do that, I could extract his cap file into csv and then do parser for any information
I want from php or other language
Author: duncanb7 replied at 2024-07-19 06:46:41
Thanks for all of your suggestion. Those tools are a good start
Expert: btan replied at 2024-07-19 06:13:35
350 points EXCELLENT
tough to sieve from raw packet on internet connectivity, probably some heartbeat scheduled to check for online .. I was thinking of even simplest such as “ping -t 8.8.8.8″ (where 8.8.8.8 is Google’s DNS Server). Leading on, if the status reads as “reply from 8.8.8.8,” the machine is online and in all other cases, the Internet connection is down. Other internet connectivity appls of similar nature include
http://sourceforge.net/projects/icm/
https://code.google.com/p/internetconnectivitymonitor/
There is another called PRTG Network Monitor that cover various scenarios as well
http://www.paessler.com/support/kb/questions/19
and possibly nagios (http://exchange.nagios.org/directory/Plugins/Network-Connections,-Stats-and-Bandwidth#/) but it is can go quite off track ... there is another such as smartsniff (http://www.nirsoft.net/utils/smsniff.html)
there is another more extensive mean such as "Munin" which surveys all your computers and remembers what it saw. It presents all the information in graphs through a web interface. But it is not Windows friendly as it may not survey Window based station - http://munin-monitoring.org/wiki/faq
Expert: eeRoot replied at 2024-07-19 05:33:11
150 points EXCELLENT
A packet capture tool will not show info on your internet connection, because it only sees traffic on your local network. Maintaining the ISP connection is a function of your edge router. Wireshark and the other tools are only seeing local network traffic, this includes traffic that is destined for the internet, but is going through one or more local nework devices first.
For monitoring of internet connectivity over time, try this -> http://www.snapfiles.com/get/iphostnetmon.html
