When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by fh_freese
at 2024-07-17 12:04:53
Point:500 Replies:19 POST_ID:829010USER_ID:11849
Folks,
This is the code I'm using
Sub InsertNewYearConsolidated() Dim ws As Worksheet, rw As Long Set ws = Worksheets("Consolidated") ws.Select 'Insert 12 rows above Totals and the spacer row rw = ws.Range("A:A").Find("Totals").Row ws.Rows(((rw - 1) & ":" & (rw + 10))).Insert Shift:=xlDown 'copy the format from the first 12 rows (6 to 17) ws.Range("A6:U17").Copy ws.Range("A" & (rw - 1)).Select Selection.PasteSpecial Paste:=xlPasteFormats Ws.Range(“A6:A17â€).Copy Selection.PasteSpecial Paste:=xlPasteValues Application.CutCopyMode = False Range("A1").SelectEnd Sub 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:
In adding lines 14 and 15 I'm getting this:
Not exactly what I am needing which is this:
Author: fh_freese replied at 2024-07-18 13:52:06
My pleasure. You have a great day also.
Expert: duncanb7 replied at 2024-07-18 13:45:37
Author: fh_freese replied at 2024-07-18 12:37:24
Thanks Duncan!
Author: fh_freese replied at 2024-07-18 12:34:48
Duncan work on this and there is a value. I'm going to give him the points
Author: fh_freese replied at 2024-07-17 15:04:08
Duncan,
You are good man and dedicated to helping us. I'll have more posts of this problem for sure - my client is taking me to on a Star Trek adventure - To boldly go....
Again,
Accept my grateful thanks and appreciation
Frank
Again,
Frank
Author: fh_freese replied at 2024-07-17 14:59:55
Duncan,
I tried everything you posted and displayed the results. Yes, you did add the months but the rest of the formatting was something I could not use. I closed this question when I discovered that all the new code that was needed was:
Range("A6:A17").Select
Selection.Copy
Range("A18:A29").Select
Right before:
Range("A1").Select
this last line of code I had.
I personally don't collect points and if there was some way to give you partial I truly would
Selection.Copy
Right before:
Range("A1").Select
Expert: duncanb7 replied at 2024-07-17 14:56:02
I'd also spent a lot time to read your question in detail and made the code even that is not matched to your need finally.
Anyway, glad to see you have solved your problem
Author: fh_freese replied at 2024-07-17 14:52:21
I've requested that this question be closed as follows:
Accepted answer: 0 points for fh_freese's comment #a40203317
for the following reason:
Duncan left me with the impression he had offered a solution, which unfortunately, was not the case. So I spent more time with the problem and saw how to do it myself.
I simply added this snippet:
Selection.Copy
problem solved
Selection.Copy
problem solved
Expert: duncanb7 replied at 2024-07-17 14:51:20
I have already done the code for the image at http://filedb.experts-exchange.com/incoming/2014/07_w29/861307/correctfill.jpg
Is it right ?
Is it right ?
Author: fh_freese replied at 2024-07-17 14:48:15
Actually, I was able to resolve this myself today. It truly was not as difficult of a fix that I though.
Thanks for your support
Author: fh_freese replied at 2024-07-17 14:07:23
I'm not sure I understand your response. Are you saying that you have provided a solution?
thanks
Frank
thanks
Frank
Expert: duncanb7 replied at 2024-07-17 14:03:07
based on my attached example to solve the rest of your issue
have a nice day
have a nice day
Author: fh_freese replied at 2024-07-17 14:02:01
Duncan,
This code maintains the row and column formatting needed.
Sub InsertNewYearConsolidated() Dim ws As Worksheet, rw As Long Set ws = Worksheets("Consolidated") ws.Select 'Insert 12 rows above Totals and the spacer row rw = ws.Range("A:A").Find("Totals").Row ws.Rows(((rw - 1) & ":" & (rw + 10))).Insert Shift:=xlDown 'copy the format from the first 12 rows (6 to 17) ws.Range("A6:U17").Copy ws.Range("A" & (rw - 1)).Select Selection.PasteSpecial Paste:=xlPasteFormats Application.CutCopyMode = False Range("A1").SelectEnd Sub 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:
From that I get this
The above is correct.
What I am getting from junk2.xlsm looks like this:
You give me the months Jan - Dec but not the formatting. When I'm adding to the worksheet I am also adding the months Jan - Dec in A18:A29. That's what's missing from the code snippet provided above --- adding Jan - Dec is my objective. I'm having some issues adding the year but I may post another question if I need to..
Expert: duncanb7 replied at 2024-07-17 13:31:19
Please see the attached file, and you delete the rows below row17, and then re-run marco
Expert: duncanb7 replied at 2024-07-17 13:16:53
Please try this code
Sub InsertNewYearConsolidated() Dim ws As Worksheet, rw As Long Set ws = Worksheets("Consolidated") ws.Select 'Insert 12 rows above Totals and the spacer row rw = ws.Range("A:A").Find("Totals").Row ws.Rows(((rw - 1) & ":" & (rw + 10))).Insert Shift:=xlDown ' ws.Range("B" & (rw - 1) & ":" & "B" & (rw + 10)).NumberFormat = "dd/mm/yyyy" 'copy the format from the first 12 rows (6 to 17) ' ws.Range("A6:U17").Copy ws.Range("A" & (rw - 1) & ":" & "A" & (rw + 10)).Select ws.Range("A6:A17").Copy Selection.PasteSpecial Paste:=xlPasteValues Application.CutCopyMode = False Range("A1").SelectEnd Sub 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:
Expert: duncanb7 replied at 2024-07-17 12:44:22
What is the result you want on Consolidated sheet after macro running. Could you put the data into sheet and send us in other file ?
Expert: duncanb7 replied at 2024-07-17 12:30:23
Sorry, ignore the previous writing, I could open it now and run it
Author: fh_freese replied at 2024-07-17 12:22:59
Sure no problem. It is attached; On the Cost Allocation Main worksheet you will find a command button with the macro
named InsertNew YearConsolidated. I added to the original code
The rest of the code is correct.
Expert: duncanb7 replied at 2024-07-17 12:10:50
Could you send us your Excel workbook with that macro so that we can run it
at our side that assist to solve the issue quickly
