When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by brucegust
at 2024-07-17 03:03:26
Point:500 Replies:6 POST_ID:829005USER_ID:11902
Unix Operating Systems;;
Towards the end of the first tutorial (http://symfony.com/legacy/doc/jobeet/1_4/en/01?orm=Doctrine), I’m asked to change the configuration of my server so it’s looking in my “bruce†folder (home/ sfprojects/jobeet/web/index.php). Here’s what I did:
# Be sure to only have this line once in your configuration
NameVirtualHost 127.0.0.1:8080
# This is the configuration for your project
Listen 127.0.0.1:8080
<VirtualHost 127.0.0.1:8080>
DocumentRoot "/home/sfprojects/jobeet/web"
DirectoryIndex index.php
<Directory "/home/sfprojects/jobeet/web">
AllowOverride All
Allow from All
</Directory>
Alias /sf /home/sfprojects/jobeet/lib/vendor/symfony/data/web/sf
<Directory "/home/sfprojects/jobeet/lib/vendor/symfony/data/web/sf">
AllowOverride All
Allow from All
</Directory>
</VirtualHost>
I’m changing the port and the root directories. Simple enough. Thing is, †home/sfprojects/jobeet/lib/vendor/symfony/data/web/sf†doesn’t exist. That may not make a difference, but when I went to see the page that’s supposedly at http://~localhost~:8080/, I get a “page not found†error. What am I doing wrong?
AllowOverride All
Allow from All
</Directory>
AllowOverride All
Allow from All
</Directory>
</VirtualHost>
Author: brucegust replied at 2024-07-17 07:10:48
I'm just going by the tutorial at http://symfony.com/legacy/doc/jobeet/1_4/en/01?orm=Doctrine
Regardless of which service I use, shouldn't my Symfony project be located within my MAMP application? How can a php page work unless it's hosted within the app? It boggles my mind to think that I'm pointing my web server to a page that's in my user folder as opposed to a file that's "hosted" with my web server.
Expert: duncanb7 replied at 2024-07-17 06:59:02
Now you are using MAMP ? why not switch to XAMPP that is better
for apache setup ,
https://www.apachefriends.org/download.html
for apache setup ,
Author: brucegust replied at 2024-07-17 06:53:21
OK, I changed the port to 9090 and when I open up MAMP after restarting it, I get this URL: http://localhost:9090/MAMP/?language=English and I get the MAMP start page.
If I try this: http://localhost:9090/home/sfprojects/jobeet/web, I get a page not found.
Things is, that doesn't surprise me because I'm assuming that MAMP is not looking for a file outside the MAMP application itself, correct? So if I don't have a "home" directory in my MAMP application, should I expect it to open up a page that's sitting in my user/bruce directory?
Expert: duncanb7 replied at 2024-07-17 05:02:07
Please answer my question ?
Try other port such as 9090 instead of 8080 since your system might be using 8080
for other application and check whether the file of index.php
is at that directory first or not
Author: brucegust replied at 2024-07-17 04:45:17
Duncan! I'm glad you're up, my friend!
When I go the shell command route, first off, I'm using this: ls home/sfprojects/jobeedt/web/index.php. I'm omitting the first "/" and I wanted you to see that, being that I'm not sure that's a deal breaker or not.
The screen print I have attached shows you, both the outcome of the command (which was successful), as well as the way I have things set up as seen in my Finder.
I have re-started Apache. I have not tried any other ports other than the ones specified in the tutorial I'm attempting to make my way through (http://symfony.com/legacy/doc/jobeet/1_4/en/01?orm=Doctrine).
What do you think?
What do you think?
Expert: duncanb7 replied at 2024-07-17 03:13:44
Did you try the port besides 8080 such as 9090 ?
Did you stop and start apache again ?
Did you find the index.php at that directory on shell command, for example, ls /home/sfprojects/jobeet/web/index.php ?
