When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by pepps11976
at 2024-07-17 02:50:10
Point:500 Replies:3 POST_ID:829004USER_ID:11498
MS SQL Server;;SQL Server 2008
Hi we are getting the following error when trying to Process our Cube
Errors in the OLAP storage engine: The attribute key cannot be found when processing: Table: 'dbo_V_Created_Contacts', Column: 'createdid', Value: '7303'. The attribute is 'Contid'.
This is the OutPut from where the Data is collected from
im not overly sure of what to look for but every thing seems populated correctly, can any one assist it finding the problem?
Author: pepps11976 replied at 2024-07-17 03:21:48
No Problem Thank You :)
in case anyone has same problem as Per Article I had To process Dimensions First Then the Cube
Expert: duncanb7 replied at 2024-07-17 03:18:24
Expert: duncanb7 replied at 2024-07-17 03:04:34
This link
http://www.ssas-info.com/analysis-services-articles/66-mgmt/1963-ssas-quick-reference-attribute-key-cannot-be-found
is found from
http://social.msdn.microsoft.com/Forums/sqlserver/en-US/c09de0db-3c84-42f3-8c5d-2f16f35a31e5/errors-in-the-olap-storage-engine-the-attribute-key-cannot-be-found-when-processing?forum=sqlanalysisservices
and suggest cause and solution for the issue.Please take a look it and
hope understand your question completely.If not, please pt it out
is found from
