When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Allpurple
at 2024-07-17 01:50:27
Point:500 Replies:4 POST_ID:829000USER_ID:11898
Spreadsheet Software;;
I want to use the contents of a cell to replace the lookup name in a different workbook. Here is an example of what I am attempting:
A B
APC Ref
128
Week_27 =VLOOKUP($A$2,'APC Collections Notices.xlsm'!Week_27,6,FALSE)
Week_28 =VLOOKUP($A$2,'APC Collections Notices.xlsm'!Week_28,6,FALSE)
Week_29 =VLOOKUP($A$2,'APC Collections Notices.xlsm'!Week_29,6,FALSE)
Week_27/28/29 etc in the formulas, refer to named areas in another workbook (APC Collections Notice.xlsm). I would like to replace the week number reference with the variable information in the same row and in column A. I have tried the following, without success:
Week_27 =VLOOKUP($A$2,'APC Collections Notices.xlsm'!A4,6,FALSE)
Week_27 =VLOOKUP($A$2,'APC Collections Notices.xlsm'!INDIRECT(A4),6,FALSE)
Please help if you can.
A B
APC Ref
128
Author: Allpurple replied at 2024-07-17 11:26:31
Hi Duncan
I'm out of time for today and will be working away from very early tomorrow morning until late Friday night, but will make a small version over the weekend to demonstrate my problem.
Thanks anyway, I will be in touch.
Bob
Bob
Expert: duncanb7 replied at 2024-07-17 11:09:28
So you can create a copy for small-size workbook that can
simulate your issue, in other words, create a simple example
for experts in order to assist you when they understand your
issue. Now what I can do just find the function in the google
for your need for tutorial, for example ,this as follows, since
I could not understand what you need
Indirect() in VBA at http://www.cpearson.com/excel/indirect.htm
OR
To call other cell B1 in other workbook, 'APC Collections Notices.xlsm, at sheet of 'Week_27' at A1 of EEpost.xls at sheet1 such as follows
A1='c: emp['APC Collections Notices.xlsm]week_27!$B$1'
You need to create simple or small-size example file and send us that will be faster to solve your issue
YOu don't need to send us the confident information, but you can similate it as simple example
The second item in vlookup is target table array to be searched in 'APC Collections Notices.xlsm' workbook at variable worksheet, right ? what the range you want from example of A1:A100 ,='c: emp['APC Collections Notices.xlsm]week_27!A1;A100', Right ?
OR
Author: Allpurple replied at 2024-07-17 09:27:16
Hi Duncan
In the examples:
A B
1 Ref
2 128
3
4 Week_27 =VLOOKUP($A$2,'APC Collections Notices.xlsm'!A4,6,FALSE)
5 Week_27 =VLOOKUP($A$2,'APC Collections Notices.xlsm'!INDIRECT(A5),6,FALSE)
The information in cell A2 is 128. The formula has to lookup 128, column 6 in a range named Week_27 in the first example and Week_28 in the second example. The named ranges (Week_27 & Week_28) are both in a workbook called APC Collections Notices.xlms. Neither of the above versions work, but if I replace the A4 or A5 variables with the written text of Week_27 or Week_28, they work just fine. The examples are only the first column of many, which I want to copy down without physically having to change the Week_?? references, in each row. The workbook APC Collections Notices.xlms is huge, containing personal and confidential information, so I am unable to copy it to you. Thanks for any light you can shed on this.
Bob
In the examples:
A B
1 Ref
2 128
3
Bob
Expert: duncanb7 replied at 2024-07-17 05:38:39
Now we would like to call Excel cell in your previous post is EEpost.xls at sheet1
and other workbook call 'APC Collections Notices.xlsm'
Could you send us the 'APC Collections Notices.xlsm' Excel workbook ?
the reference for vlookup
http://www.techonthenet.com/excel/formulas/vlookup.php
where $A$2 is equa to 128, the second item in vlookup is table array you want to search 128, Right ?
what is table array range in which workbook ?
the third item is seach result at column index 6, right ? on which workbook ?
So please write more your question in detail that will be faster to solve the issue.
Up to this moment, I could not understand what you are solving for
Send us both of your workbook, EEpost.xls and 'APC Collections Notices.xlsm'
that will be easier to understand your question before finding out the solution
