When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by gprempeh
at 2024-07-17 01:05:27
Point:500 Replies:2 POST_ID:828999USER_ID:10
Microsoft Excel Spreadsheet Software;;Microsoft PowerPoint Presentation Software
i have a number of charts on a worksheet, i want to create a macro that copies each of the charts into a separate slide in powerpoint. Thank you!
Expert: JSRWilson replied at 2024-07-17 02:31:34
This would be the basic code (Late bound) You may need to improve it to suit your needs.
If the charts are not directly on the sheets but have been moved to chart sheets the code would be different.
Sub pptpaster()Const ppLayoutTitleOnly = 11Dim i As Integer'does not require reference to PowerPointDim pptapp As ObjectDim pptPres As ObjectDim pptsld As ObjectDim s As IntegerDim ocht As ObjectSet pptapp = CreateObject("PowerPoint.Application")pptapp.Visible = TrueSet pptPres = pptapp.Presentations.AddFor s = 1 To ActiveWorkbook.Sheets.CountFor i = 1 To Sheets(s).ChartObjects.CountSheets(s).ChartObjects(i).CopySet pptsld = pptPres.Slides.Add(pptPres.Slides.Count + 1, ppLayoutTitleOnly)Set ocht = pptsld.Shapes.Paste(1)ocht.Left = 100ocht.Top = 200NextNextEnd Sub 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:
Expert: duncanb7 replied at 2024-07-17 01:12:28
There is example tutorial to let you to paste the active excel chart into the Active PowerPoint Slide at
http://peltiertech.com/Excel/XL_PPT.html
Hope understand your question completely.If not , please pt it out
