When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Bright01
at 2024-07-16 22:12:44
Point:500 Replies:21 POST_ID:828997USER_ID:11896
EE Pros,
I'm a advanced novice Excel user trying to run a substantial sales operation. I have a worksheet that has approximately 5000 Customers so, 5000+ rows and approx. 30 columns of data. Every time I have to look up a Customer, I am using the Filter to uncheck "All" and look down the list for the particular record. This is nerve racking as it can take 30 seconds or more to look up a particular record in column A.
What I'm looking for is a small piece of VBA Code that can assign a "key" such as "L" (for look up) and up pops a box that seeks the character string typed into the box focused on either a particular column, say "A" or has a option to "search all" which would be the entire sheet.
Can I get some help with this? I think it's rather simple for someone who knows VBA. I have the skills to integrate it into my worksheet...but simply need help with the lines of code, search algorithum and probably the form that needs to come up in order to perform the search (with link to the assigned key (such as Ctrl+L -- for Look Up).
Much thanks in advance,
B.
B.
Author: Bright01 replied at 2024-07-20 05:46:39
Duncan,
Again, thanks for the help!
B.
B.
Author: Bright01 replied at 2024-07-19 12:54:02
I've requested that this question be closed as follows:
Accepted answer: 0 points for Bright01's comment #a40206172
for the following reason:
Duncan,
Thank you very much for the work here. I'm using it as a base and have learned new things thanks to you. I left the other question open because Glenn also weighed in and I'm learning how to do the same thing a different way.
Again, much thanks and wishing you "my best"!
B.
Duncan,
B.
Author: Bright01 replied at 2024-07-19 08:30:57
Duncan,
How come we didn't just write a macro that brings up the Find Function as we originally had thought to do? I couldn't get the macro to record the simple CTRL+F keystroke......
B.
B.
Author: Bright01 replied at 2024-07-19 08:29:30
Module 1
Sub FunctionkeyFind()
Dim FindString As String
Dim Rng As Range
FindString = InputBox("Enter a Search Value")
If Trim(FindString) <> "" Then
With Sheets("PMQ_Sales_Pipeline").Range("B:B")
Set Rng = .Find(What:=FindString, _
After:=.Cells(.Cells.Count), _
LookIn:=xlValues, _
LookAt:=xlWhole, _
SearchOrder:=xlByRows, _
SearchDirection:=xlNext, _
MatchCase:=False)
If Not Rng Is Nothing Then
Application.Goto Rng, True
Else
For Each Cell In Range("B1", Range("B" & Rows.Count).End(xlUp))
If InStr(Cell, FindString) <> 0 Then
GoTo final
End If
Next Cell
MsgBox "Nothing found"
Exit Sub
End If
For Each Cell In Range("B1", Range("B" & Rows.Count).End(x1up))
GoTo final
End If
Next Cell
End With
End If
final:
Cell.Select
End Sub
This Workbook
Private Sub Workbook_Activate()
Application.OnKey "+^{F}", "functionkey"
End Sub
Dim Rng As Range
LookIn:=xlValues, _
LookAt:=xlWhole, _
MatchCase:=False)
Else
GoTo final
End If
Next Cell
Exit Sub
End If
GoTo final
End If
Next Cell
End With
End If
final:
Cell.Select
End Sub
This Workbook
End Sub
Author: Bright01 replied at 2024-07-19 08:08:58
Yes. Fair enough. I've already put it in my production system and am making the changes as I get your recommendations. Let me send you the code I have now in the Workbook.
B.
B.
Expert: duncanb7 replied at 2024-07-19 08:04:55
Could you summarize what code you have and what last issue you have on new thread that
will be easier and faster for other experts to look into it ?
Author: Bright01 replied at 2024-07-19 08:03:57
Also, where you have "MatchCase:=False)", should that mean that it doesn't have to match cases? Right now I have to put in exactly the Case for it to find a Name. Example; FedEx vs. fedex.
B.
B.
Author: Bright01 replied at 2024-07-19 07:59:23
Interesting on this pass.... if I try to find a record "above" where the cursor is in the worksheet, I get an error but it goes to the spot.
B.
B.
Expert: duncanb7 replied at 2024-07-19 05:34:21
Using widcard with find is hard, I try to use Instr with find
For Each Cell In Range("A1", Range("A" & Rows.Count).End(xlUp)) If InStr(Cell, FindString) <> 0 Then GoTo Final End If Next Cell 1:2:3:4:5:
Author: Bright01 replied at 2024-07-19 04:47:59
Duncan,
B.
Duncan,
B.
Expert: duncanb7 replied at 2024-07-19 04:29:45
Put the work_activate at the sheet of "ThisWorkbook" using VBA editor
and the function will be activated automatcially once the file is re-open.Please also read the attachment for example code
Private Sub Workbook_Activate() Application.OnKey "+^{F}", "functionkey"End Sub 1:2:3:
Author: Bright01 replied at 2024-07-19 03:58:38
Duncan,
Here's what I tried; no progress here.
Sub Macro1()
Application.OnKey "^{F}"
End Sub
Sub Macro1()
End Sub
Author: Bright01 replied at 2024-07-18 05:01:00
I did! It didn't work. It doesn't get any smaller then two keystrokes.
Watched the tutorial.... but doesn't address a Control + F recording. Here's what I'm doing:
1.) Selected Record Macro
2.) Selected Relative Referernce
3.) Control + F (to initiate the "find function")
4.) Stopped the Macro
5.) Viewed the Macro
I get Nothing in the Macro.
Expert: duncanb7 replied at 2024-07-18 04:42:19
try a small and test example to start after viewing the video, work around it, you will get it
Author: Bright01 replied at 2024-07-18 04:37:18
B
B
Expert: duncanb7 replied at 2024-07-18 04:20:00
Author: Bright01 replied at 2024-07-18 04:08:59
Duncan,
I know how to link/assign the macro. I tried approach 2, by recording a macro, selecting CTRL+F, up came the find box, I stopped the Macro record. And got nothing. Can you give me some coaching here or show me an example?
Thank you,
B.
Thank you,
B.
Expert: duncanb7 replied at 2024-07-18 03:57:20
There is three wayes to do this
1-on VBA editor, try to write your example function macro called test()
On Excel 2007, insert shape such as circule, rect,...etc.
And right click the sharp and then select test() macro from the tab of "Assign Macro"
2-You can use "Macro Recoding" tab to recode all function(atl+F) you click on the Excel sheet and
then look into the VBA editor, the record macro will save all your click, editing, draw, selecting action..etc on your Excel sheet into the VBA macro
3-take a look at onkey on VBA at http://msdn.microsoft.com/en-us/library/office/ff197461(v=office.15).aspx
Author: Bright01 replied at 2024-07-18 02:26:42
Rgonzo and Duncan,
Very helpful! Here's my question; can you guys show me how I can construct a simple "Button" that drives a macro that reflects using the "Function Keys" in Excel? Since I have users using the Worksheet, I'd like to make this very simple. If I can have a single Button that when pressed, it drives the specific Function, such as Alt. + F, then I don't have to train them on the shortcut.
Much thanks,
B.
Much thanks,
B.
Expert: duncanb7 replied at 2024-07-16 23:40:40
There is all function key on Excel workbook,
http://office.microsoft.com/en-001/excel-help/excel-shortcut-and-function-keys-HP010073848.aspx
Hope it will assist you to solve your issue or give you some hint
Expert: Rgonzo1971 replied at 2024-07-16 23:12:21
Why not use Ctrl-F
if only select Col A first, it will only lookinto the column A
Regards
Why not use Ctrl-F
Regards
