When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by rbudj
at 2024-07-16 18:32:45
Point:500 Replies:8 POST_ID:828996USER_ID:11872
Apache Web Server;PHP Scripting Language;Web Servers
I design websites in html/css/php and javascript. My hosting is all done in the cloud with a hosting provider.
I am faced with a new task which is to design an Intranet site for a small business using my technologies.
I have no clue how to run my own Linux and Apache server.
Should I be looking at WAMP or LAMP?
Author: rbudj replied at 2024-07-20 11:03:33
All answers were helpful. Thank you.
Expert: Gary replied at 2024-07-17 07:32:30
83 points EXCELLENT
Yes
Author: rbudj replied at 2024-07-17 07:31:10
Thanks for the responses. In this particular case, the network is running Windows Server 2012 R2. I can easily install a Windows 7 or Windows 8 tower. So I understand, I can use either the server or a windows desktop to run either WAMP or XAMPP. So LAMP would be if I am running a version of Linux. Correct?
Expert: duncanb7 replied at 2024-07-17 06:20:20
83 points EXCELLENT
-WAMP (like the name says) runs only on Windows (either 64/32-bit) with light version and less feature than XAMPP
- XAMPP for Windows, XAMPP for Linux, for Mac and for Solaris with full version
it has too many additional features including support of perl, filezilla, mercury mail and some scripts. and is available for all major operating system including windows, mac, Linux
-Lamp is for linux and doesn't have too many feature as Xampp
So go to download xampp for a try a https://www.apachefriends.org/download.html
Expert: Dave Baldwin replied at 2024-07-16 21:08:52
83 points EXCELLENT
I would recommend that you look at both WAMP http://www.wampserver.com/en/ and XAMPP https://www.apachefriends.org/index.html which are both available for Windows. They both include Apache, PHP, and MySQL with phpMyAdmin and some other software. Neither are recommended for public sites since they are intended to be easier to use than a LAMP machine.
If it is necessary that your site runs on Linux for some reason, you can have someone else set it up and let you build the site and access it like you do on your hosted sites now.
Expert: Gary replied at 2024-07-16 21:07:55
83 points EXCELLENT
LAMP and WAMP are the same thing - there is no mainstream version
The only difference is that LAMP is for installation on Linux and WAMP is for installation on Windows - notice the subtle difference - apart from that they do the exact same thing (and then you have MAMP as Scott has pointed out)
Expert: Ray Paseur replied at 2024-07-16 18:48:03
84 points EXCELLENT
My sense is that LAMP is more mainstream and offers better access to high-level experts. YMMV and other will have other opinions. Perhaps the most valuable advice anyone can give about "what is better" goes to "what do you already know?"
Expert: Scott Fell (padas) replied at 2024-07-16 18:46:31
84 points EXCELLENT
If you are on windows, you want wamp http://www.wampserver.com/en/ otherwise, you probably want https://www.apachefriends.org/index.html and if you are on a mac, http://www.mamp.info/en/
If you mean for your live site, you can use php/mysql on windows just as you can with linux.
