When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Camilla
at 2024-07-15 20:34:56
Point:500 Replies:7 POST_ID:828987USER_ID:11642
C# Programming Language;Programming for ASP.NET;.NET
I have a long string and there's a text in it
Patient: Robert Someone (DOB 1/23/1927) or Patient: Test Tester (DOB 1/1/1920)
I want to get everything after Patient: up to the close parenthesis
I did this but this picks up everything after "Patient:"
string tobesearched = "Patient:"; string code = text.ToString().Substring(text.ToString().IndexOf(tobesearched) + tobesearched.Length); 1:2:
Author: Camilla replied at 2024-07-16 15:54:22
That worked, Kaufmed.
Author: Camilla replied at 2024-07-16 11:00:00
Let me try it. The issue is that Robert Test (DOB 1/23/1927) is repeated in 2 places. So, it takes the first occurrence, and but then looks for the second ")" and takes everything in between.
I'll try your code as well. I found another section of the document that I could use to get the info, but will still try your code.
Expert: kaufmed replied at 2024-07-16 08:37:10
If you are simply trying to find up to the closing paren, then a simply IndexOf should suffice:
e.g.
e.g.
string code = text.ToString().Substring(text.ToString().IndexOf(tobesearched) + tobesearched.Length);int closingParen = code.IndexOf(')');string match = code.Substring(0, closingParen); 1:2:3:
If you want to ultimately get each substring, then you repeatedly call IndexOf. It takes an additional parameter which specifies the starting index to begin searching from. You can use the closingParen variable for this.
e.g.
int startAt = closingParen + 1;closingParen = code.IndexOf(')', startAt);match = code.Substring(startAt, closingParen - startAt); 1:2:3:4:
Author: Camilla replied at 2024-07-16 07:27:02
Actually, it works but since that line is repeated twice, it gets everything in between.
Author: Camilla replied at 2024-07-16 07:20:26
Between didn't work.
I want this Patient: Robert Test (DOB 1/23/1927)
But it gets everything else after it too
Monday, July 14. 201407/14/2014 9:30 AM Retina Health Center
cc: Gary Test; Doctor Access Test
Doctor Access Test LI 3
Page 2 of 2
Page 2 of 2
Expert: Miguel replied at 2024-07-15 21:32:25
Your code is only fetching the string after your left string delimiter "Patient:".
Your code needs to check for both before and after string. Check between method.
Usage:
Usage:
string leftDelimiter = "Patient:";string rightDelimiter = "(";string code = text.ToString().Between(leftDelimiter , rightDelimiter); 1:2:3:
Note: if required the extension method could be converted to static method. e.g. If your project uses .NET 3.0 or earlier.
Expert: duncanb7 replied at 2024-07-15 21:08:42
Patient: S*\)
Try this regular expression
