When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by zachvaldez
at 2024-07-15 08:17:22
Point:385 Replies:10 POST_ID:828981USER_ID:11517
Cascading Style Sheets (CSS);;
There is no align attribute in Html 5.
What is the css to attain this align,ent?
Author: zachvaldez replied at 2024-07-22 06:47:59
Using this way it would lined up. I took away the <h3> and <h4> 's tags and replaced with css. Thanks
Expert: Scott Fell (padas) replied at 2024-07-15 15:07:41
385 points EXCELLENT
CSS
HTML
Take a look at http://www.codecademy.com/tracks/web and go through the HTML and CSS courses. What you are asking should be very basic. I think a several hour time out for this will be very beneficial.
Author: zachvaldez replied at 2024-07-15 14:52:24
Can you give am example using div or span to change font size that
display like <h3>.<h4> and are lined up? Thnks
Expert: Scott Fell (padas) replied at 2024-07-15 09:35:58
You are using bootstrap so the alignment would be via your columns. Looking at your code (removing your asp tags) http://jsbin.com/girax/1/edit you can see it works as expected as is.
My guess is you have some other css that is in play. Can you please provide a link to your rest page to look at?
Also, your H tags should be used just as if you are writing a term paper. You have 1 topic sentence (<h1>) and some supporting sub topic sentences (<h2>). Inside of your h2 tags, you may have some other sub topic sentences that should be in order h3,h4,h5,h6.
There are some jquery plug ins that may rely on the use of H tags, but you want to keep the H tags for what they are and not a design element. If you are using them for labels, I would suggest to use a div or span with a class to change the font and avoid using H tags for that purpose.
Expert: COBOLdinosaur replied at 2024-07-15 09:29:47
Oh bootstrap... like I said semantically invalid code. I'm out.
Cd&
Cd&
Expert: Scott Fell (padas) replied at 2024-07-15 09:27:01
Code snippet placed in a code box
padas
Topic advisor
padas
Topic advisor
Author: zachvaldez replied at 2024-07-15 09:23:51
Both <h3> and <h4> are in same div class="col-md-12"(bootstrap)
To elaborate further. If I don't make them all <h3> , it would not lined up. I'd like th ID to have smaller font size<h4>.
<div class="col-md-12"> label class="col-md-1 col-md-push-1 text center>ID#</label> <div class="col-md-1"> <h4> <strong><asp:Label ID="lblID" runat="server"></asp:Label></strong> </h4> </div> <label class="col-md-2 col-md-push-1">Last Name</label> <div class="col-md-2 col-md-pull-1"> <h3> <strong><asp:Label ID="lbllastname" runat="server"></asp:Label></strong> </h3> </div> <label class="col-md-2">First Name</label> <div class="col-md-2 col-md-pull-2"> <h3> <strong><asp:Label ID="lblfirstname" runat="server"></asp:Label></strong> </h3> </div> </div> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:
Expert: COBOLdinosaur replied at 2024-07-15 09:07:06
vertical-align only works on table cells. for it to work on an h tag you would need to specify display:table-cell as well as the vertical-align.
However the question does not make a lot of sense because it is illogical to have h3 and h4 in proximity to each other in a semantically valid page.
Cd&
Cd&
Expert: duncanb7 replied at 2024-07-15 08:30:19
align attribute is depreciated on HTML5, using CSS to replace it , for example,
<style type="text/css">h3,h4 {text-align:center;vertical-align: top;}</style> 1:2:3:4:5:6:
Hope understand your question completely, If not, please point it out.
Expert: Randy Poole replied at 2024-07-15 08:19:15
please elaborate
