When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by gvilbis
at 2024-07-15 02:40:29
Point:500 Replies:5 POST_ID:828977USER_ID:10
Microsoft Excel Spreadsheet Software;;VB Script
i wrote a macro in excel and i would like that after 3 months it will not be able to run any more until i will put new pass, how do i do that?
thanks
gvilbis
thanks
gvilbis
Expert: duncanb7 replied at 2024-07-15 05:13:26
Expert: itjockey replied at 2024-07-15 03:09:58
20 points EXCELLENT
ooppps sorry seen post after posting.
Expert: itjockey replied at 2024-07-15 03:09:13
20 points EXCELLENT
I don't write code but my logic says.
A Macro password protected as mention by Mr.Duncan
B Need a code line which match date with todays date i.e. =TODAY() if it is after prescribed date then Don't execute.
Drawback - any one can fool this by changing system date ;(
Expert: duncanb7 replied at 2024-07-15 02:47:07
440 points EXCELLENT
OR you can set expire date for the macro on VBA
the following code is reference only.
You can put it the "ThisWorkbook" in the workbook
When you open new workbook and press atl-F11, it will
show a few sheets such sheet1(Sheet1),Sheet2(Sheet2),Sheet3(Sheet3) and "ThisWorkbook".
The macra will run first in proiority in the "ThisWorkbook" when
the workbook opens
Hope undrestand your question completely.If not , please point it out.
the workbook opens
Sub AutoOpen()ExpirationCodeEnd SubSub ExpirationCode()Dim ExpirationDate As DateExpirationDate = DateSerial(2014, 10, 11)If Now() >= ExpirationDate ThenMsgBox “Trial Period ended on ” & CStr(ExpirationDate) & “.”ThisWorkbook.Close savechanges:=FalseEnd IfEnd Sub 1:2:3:4:5:6:7:8:9:10:11:
Expert: duncanb7 replied at 2024-07-15 02:43:45
20 points EXCELLENT
Could you do it by putting password on macro ?
take a look at this about protect macro on Excel
http://www.excel-easy.com/vba/examples/protect-macro.html
