When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-07-13 05:14:19
Point:500 Replies:8 POST_ID:828970USER_ID:11059
Windows 7;System Utilities;Anti-Virus Applications
Similar issue is shown before casued by outdated Broadcom driver from this articel
http://blogs.technet.com/b/markrussinovich/archive/2008/04/07/3031251.aspx
Now I'm going to solve my case issue on my window 7 comptuer, and I am using taskmanager and its CPU monitor found out the process name called "System" drive the most CPU usage around 60% Now I downoad Process Explorer for monitor CPU performance from microsoft, and it show the name of "system" process has two process have CPU spike, one is called hal.dll and others are ntoskrnl.exe which is MS NT kernel at c:windowssystem32.
How can I kill hal.dll and ntoskrnl.exe process both drive CPU usage at most in order
to reduce CPU usage ?
Expert: John Hurst replied at 2024-07-13 09:46:18
Thank you and I was happy to help.
Author: duncanb7 replied at 2024-07-13 09:41:02
Anyway, at least now it is okay. I will make new thread the choice of virus software(including registry key scan)
Expert: John Hurst replied at 2024-07-13 09:36:54
OK, so it appears viruses were the cause of the issue. I think Malwarebytes is very good value - much better value than free. You did solve the problem with it.
Author: duncanb7 replied at 2024-07-13 08:42:32
Thanks for your quick replies that work and solve my issue.
I am using those virus scan as follows
Norton Internet Security that just include filesystem scan and site attack scan only.
McAfee Security that just site attack or filesystem scan
Malwarebyte that seems it is the best including registry, memory, filesystem, heuastic analysis, site attack scan
Finally, I download trial of Malwarebyte and fix those detected objects on my computer and work around and let it in sleep and wake-up mode and turnoff/on computer, running a lot video on at the same time with many browser intstances enabled, so far
the high CPU usage overall 60% is gone and my computer is running properly without any hot around the regulator area, at least within 3 hours
Do you think Malwarebyte ,https://www.malwarebytes.org/, is the best choice between those vendors, it is worth to pay for it after 14-day trial around $US30 ?
OR there is free and good virus including registry scan on internet ?
Expert: John Hurst replied at 2024-07-13 05:37:26
A broken fan can cause overheating but that does not usually cause high CPU.
A process driving the CPU to its maximum speed can cause the machine to get hot but not necessarily overheat.
Check to see if you have a third party power manager and if you do, reinstall it. But I do not think this is the issue.
Expert: John Hurst replied at 2024-07-13 05:32:41
You have an abnormal problem with the computer.
Viruses: In addition to the scan you did, also scan with Malwarebytes. It may find things you own AV did not find.
If you are certain it is not a virus, try a Windows 7 Repair Install. You can do this with the Windows 7 DVD and sometimes with the on-board recovery partition. Be sure to back up the computer first. Here is a Seven Forums Tutorial to assist you.
http://www.sevenforums.com/tutorials/3413-repair-install.html
Author: duncanb7 replied at 2024-07-13 05:27:53
I tried to reboot my computer, there is no issue but when I work around with my Chrome
browser for connecting to external website for a while such as 1 hour and then let the computer in sleep mode or leaving my desk for outside for hours, and then come back home and touch my computer, the overall %60 CPU usage is appearing on taskmanager
and the HP laptop is hot.
I check Norton anti-virus software that doesn't find any virusrowse
and even I quit all program or browser, the 60% high CPU usage is
shown on the taskmanager
Expert: John Hurst replied at 2024-07-13 05:22:54
A properly operating XP, Vista, Seven or Eight machine will run less than 5% CPU more than 95% of the time.
So if your machine is always at 60% (and I assume you mean 60% overall), look for:
1. A misconfigured process (but that would not likely show up as System.
2. A virus. This is the most likely cause.
Scan your machine with your own anti virus and then also with Malwarebytes. Clean up viruses that appear and when done, restart and test.
