When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by bigeven2002
at 2024-07-12 22:06:35
Point:500 Replies:8 POST_ID:828968USER_ID:11649
Windows 8;Windows Server 2012;Remote Access Software
Hello,
I have setup a Windows 8.1 virtual machine on windows server 2012 R2 Hyper-V. It is also using RemoteFX. When I connect to the Windows 8 machine via remote desktop, remotefx is working correctly, but the screen goes blank after 1 minute idle.
On both Windows 8 and 2012 and have turned off PCI express power management and set the monitor to turn off never. But the screen still blanks after 1 minute. Is this by design or did I misconfigure something?
Expert: duncanb7 replied at 2024-07-17 02:28:49
Author: bigeven2002 replied at 2024-07-17 02:16:12
Found culprit, award points for participation.
Author: bigeven2002 replied at 2024-07-12 23:35:14
No, Ctrl Alt End, disconnect, reconnect, anything brings it back. The problem is that it goes blank after 1 minute. Even after all that. All I have to do is not touch the keyboard or move the mouse for 1 minute, then it goes blank. And...I as I was typing this I just realized what happened, stupid of me to overlook this, it was the screensaver. It was set to activate after 1 minute.
Expert: duncanb7 replied at 2024-07-12 23:20:20
What you mean> you fix the issue the screen not blank anymore after disconnect and conect or Cltr-Alt-End, right ?
Author: bigeven2002 replied at 2024-07-12 23:16:26
Disconnect and connect brings it back. Control Alt End does too. But any key or mouse over does. I can get the display back, I am just trying to keep it from suspending after 1 minute of being idle.
Expert: duncanb7 replied at 2024-07-12 23:11:31
connect to the Windows 8 machine via remote desktop->disconnet->connect
Did you try Ctrl-Alt-End?
Author: bigeven2002 replied at 2024-07-12 23:09:17
Thanks for the reply. Sorry I forgot to clarify, if I move the mouse over the window or press an key, the screen comes back. It's the equivalent of the monitor going to sleep. The audio also stops too so it is like the connection is suspended until I mouse over or press a key.
The drivers are the absolute latest available from Nvidia. The card is NVS 510. The drivers are windows 2012 certified. The resolution is at a fixed non full screen - 1400x900. I'm not sure what you mean by disable and enable the connection.
Expert: duncanb7 replied at 2024-07-12 22:27:18
Please try this suggestion as follows
1. When you get a blank screen , wait a while, and then type Ctrl-Alt-End. Does that produce a
response?
2. Ensure that the video drivers are updated to the
manufacturer's latest version, not left at XP SP2 level.
3-try to disable and enable connection, and change to an explicit monitor resolution (not 'fuill screen') under the Display tab.
response?
