When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by rberke
at 2024-07-12 01:58:24
Point:500 Replies:12 POST_ID:828960USER_ID:11861
I thought this would work, but it doesn't. =countif(a1:a5,"*#*")
To demonstrate, put 999999 into a1 through a5 then make the column 1 character wide.
I have a workaround that uses vba, but it is very slow. It uses .cells.find (what:="#") and loops through the selected range.
I would much prefer an solution that uses an excel worksheet function.
Author: rberke replied at 2024-07-19 02:16:11
Martin's vba code was simple and worked, so I gave him points. My own code is more complicated by much faster so I gave myself the best answer.
Duncan's attempt avoided VBA. so it would have been ideal. Unfortunately, it did not work if any of the numbers had decimals, commas or other formatting.
Author: rberke replied at 2024-07-15 09:01:54
I simplified my code, then did a little more testing. It turns out that Martin's code is faster than my code when more than 20% of the cells have ###, For instance, when I had 20000 cells which ALL had ###, My code took 5 times longer than Martin's. For my purposes, this rarely happens, so I will continue to use my own code. Nonetheless, Martin's might be "better" for other people.
Sub CountPoundSigns()
Dim time As Double
time = Now() ' AccurateNow() ' < my personal.xls has an AccurateNow function which is far more accurate than Now().
Dim cell As Object, cellA As Range, cnt As Long
With ActiveSheet.UsedRange.Columns(1)
Set cellA = .find(what:="#", LookIn:=xlValues, LookAt:=xlPart, _
matchcase:=False, SearchOrder:=xlByRows)
If Not cellA Is Nothing Then
Set cell = cellA
Do
cnt = cnt + 1
Set cell = .FindNext(cell)
Loop While cell.Address <> cellA.Address
End If
End With
MsgBox cnt & " " & (Now()- time) * 24 * 60 * 60
End Sub
Dim time As Double
Set cell = cellA
Do
cnt = cnt + 1
End If
End With
End Sub
Author: rberke replied at 2024-07-14 13:55:19
On my machine your code took 6 seconds for 20000 rows.
my code took less than a second.
When I originally posted this question, I had not actually implemented my workaround, so I did not realize how fast it would be. It turns out it is blazing fast, so I have actually accomplished what I wanted.
I will close the question.
Expert: duncanb7 replied at 2024-07-14 10:36:12
Doing it on Excel cell that is not easy one for your case even I tried it to closer one. I suggest you
to do it on VBA to pick easier way
Have a nice day , talk your tomorrow
Expert: duncanb7 replied at 2024-07-14 10:28:44
I tried that works at my side no any issue at all
Just open a new sheet to test those suggestion from the posts
Expert: MartinLiss replied at 2024-07-14 10:28:10
Martin, the goal was something faster than my workaround. Your solution is simpler but a LOT slower.
Mine took 1.5 seconds for 100,000 records. Out of curiosity how long did your's take? BTW if your interested I have an article on timing code if you want an accurate number. Author: rberke replied at 2024-07-14 10:25:49
It cannot work reliably. Demonstrate yourself. Put 123456 into cell a1 and a2. Format a1 as $#,##0.00 and a2 as #0
You will see a1 displays ### and a2 displays 123456. But then both have len = 6
Expert: duncanb7 replied at 2024-07-14 10:08:11
so len() is not related to the cell formated or not, just
make simple example on a new sheet and test my code for Excel cell before
concluding it
concluding it
Expert: duncanb7 replied at 2024-07-14 10:04:52
Please let us know what you want to let it work on Excel cell formula or VBA ?
it seems VBA is better, and the speed is not such slow
Author: rberke replied at 2024-07-14 10:03:00
Duncan: I should have mentioned the cells are formatted, so Len function will not work at all.
I suspect that there is no solution that is better than mine, but I will leave the problem open for a while longer in hopes of another approach.
rberke
Dim rng As Range
Dim cell As Object, firstaddress As String, fnd As Range
Set cell = .Find(what:="#", LookIn:=xlValues, LookAt:=xlPart, _
MatchCase:=False, SearchOrder:=xlByRows)
If Not cell Is Nothing Then
firstaddress = cell.Address
Do
If fnd Is Nothing Then
Set fnd = cell
Else
Set fnd = Union(fnd, cell)
End If
Loop While cell.Address <> firstaddress
End If
End With
MsgBox fnd.Cells.Count
Exit Sub
End Sub
rberke
Dim rng As Range
Do
Set fnd = cell
Else
End If
End If
End With
Exit Sub
End Sub
Expert: MartinLiss replied at 2024-07-13 09:17:56
You can't use worksheet functions because they all look at the stored value of the cells and not at their appearance.
With 100,000 rows this takes only 1.5 seconds to run.
Sub CountPoundSigns()Dim lngCount As LongDim lngRow As LongFor lngRow = 1 To ActiveSheet.UsedRange.Rows.Count If InStr(1, Cells(lngRow, 1).Text, "#") Then lngCount = lngCount + 1 End IfNextMsgBox lngCountEnd Sub 1:2:3:4:5:6:7:8:9:10:11:
Expert: duncanb7 replied at 2024-07-12 03:59:58
It may be better doing on VBA
For Excel cell,I try to compare the length of cell and cell width to solve the issue that is what I can do but that is not good one if narrow width is equal to one character, If length of cell is greater than cell width, it means the cell has pound sign(#).
please try it as follows for at least narrow width=2.For narrow width=1, it will work sometimes and
sometimes not. So you need to work around for this
=SUMPRODUCT(--(LEN(A1:A5)>CELL("width",A1)))
Be reminded need to do automatic update cell formula for refresh cell if the columnwidth is changed by Excel: tools->options.caluation->calcuation->automatic
