When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by canesbr
at 2024-07-11 12:45:21
Point:500 Replies:36 POST_ID:828957USER_ID:11857
Office & Productivity Software;VB Script;Microsoft Excel Spreadsheet Software
Looking for an Excel VBA script that would search for an open browser page window (Chrome or IE tab) by caption or URL and do an Application.Sendkeys("^a^c")
Regards
Brian
Regards
Brian
Expert: aikimark replied at 2024-08-07 13:20:27
Note to future readers: Stepping through code that does windows automation (appactivate and sendkeys) does not work. You have to execute the code either from the immediate window or from the menus.
Author: canesbr replied at 2024-08-07 12:55:41
Expert: aikimark replied at 2024-08-07 12:47:59
That's possible. You will probably have to use the msxml2.serverhttp object if we want to glom those pages' data without actually using a browser.
Author: canesbr replied at 2024-08-07 12:35:19
No, it's not malware, it's a legitimate pay to use website.
You need a userid and password to access. I think I cannot post that.
If possible you could do a join.me and take a look at it on my computer?
Regards
Brian
Regards
Brian
Expert: aikimark replied at 2024-08-07 12:28:52
what is the exact URL, including application and program parameters that you are using?
Expert: aikimark replied at 2024-08-07 12:21:52
I think I should alert you to the possibility that the web page you linked to is a .exe and might run the risk of malware.
Author: canesbr replied at 2024-08-07 12:15:43
Hereto attached
Regards
Brian
Regards
Brian
Author: canesbr replied at 2024-08-07 12:14:10
Hi @aikimark
That kind of works if the page is all in HTML
I have a page that returns the string below, but the page actually looks like the attached.
So I would need a Sendkeys ^a^c
But when I tried that the focus was not on the web page so it copied the VBA script.
Is there a way to get the focus on the webpage so that the sendkeys would copy that webpage?
Regards
Brian
?strHTML
<!DOCTYPE html>
<!-- CANNEX UID:71bae71a-1954-43b0-b74e-3684cd938a07 -->
<!-- This template is used for specific errors -->
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1" />
<link rel="stylesheet" type="text/css" href="/style.css" />
<title>CANNEX Financial Exchanges Limited</title>
</head>
<body>
<hr />
<img src="/Autobahn/images/swsexcl.gif" alt="" />
<script type="text/javascript" language="javascript">
switch(12001)
case 2210:
document.write("<p>The system is currently unavailable. Please try again in 5 minutes.</p>")
document.write("<p>Le système n'est pas fonctionnel pour l'instant. Veuillez essayer à nouveau dans 5 minutes.</p>")
break
case 2618:
document.write("<p>The system is currently busy, please try again.</p>")
break
case 12001:
document.write("<p>You must specify an application name in the URL. (Application=...)</p>")
document.write("<p>Please note that accessing this page using a bookmark will not work.</p>")
break
default:
</script>
<br />
Reference: 12001<br />
Version: 5.01.00 Build 2
<hr />
</body>
</html>
Regards
Brian
?strHTML
<!DOCTYPE html>
<html>
<head>
</head>
<body>
<hr />
switch(12001)
case 2210:
break
case 2618:
break
case 12001:
break
default:
</script>
<br />
<hr />
</body>
</html>
Expert: aikimark replied at 2024-08-03 13:26:13
If you need some browser automation via VBA code, I can recommend Selenium.
Expert: aikimark replied at 2024-08-03 13:24:49
Dim oXMLHTTP As Object Dim strHTML as string Set oXMLHTTP = CreateObject("MSXML2.XMLHTTP") oXMLHTTP.Open "GET", "http://yourtargetwebsiteURL", False oXMLHTTP.Send Do Until oXMLHTTP.ReadyState = 4 DoEvents Loop If oXMLHTTP.Status = 200 Then strHTML = oXMLHTTP.responsetext 'add your parsing code here 'and then push the result into your worksheet End If 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:
Expert: thenelson replied at 2024-08-03 13:20:39
>Are you saying that there are Access VBA routines in your link that I could use in Excel VBA?
The routines should work in Excel with very little modification.
>Are the routines restricted to Internet Explorer?
Yes, FF and Chrome do not support automation so interfacing with them via VBA is a lot more complicated.
Author: canesbr replied at 2024-08-03 13:13:59
@Aikimark
Nope. Would you have an example I can work off of?
Regards
Brian
Regards
Brian
Expert: aikimark replied at 2024-08-03 11:42:06
I supplied a generic solution. Your environment may not be suitable.
Other than sending keys to copy the page, have you considered using the MSXML2.XMLHTTP object?
Author: canesbr replied at 2024-08-03 11:07:34
@TheNelson
I am looking to do this in Excel VBA.
I looked but did not see.
Regards
Brian
Regards
Brian
Author: canesbr replied at 2024-08-03 11:04:34
@aikimark
The AppActivate appears to activate something..... but the send keys doesn't seem to work in this instance
AppActivate "MSN.com - Windows Internet Explorer"
SendKeys "^a^c"
So the appactivate works for IE
But, how to determine the app or caption for apps like Chrome or Firefox that don't show the normal titlebar. That is why I wanted to loop through and find the app instance (and tab) name that contains the text I am looking for.
Regards
Brian
SendKeys "^a^c"
Regards
Brian
Expert: aikimark replied at 2024-07-31 06:54:10
There's no need for an API call
On Error Resume NextAppActivate "Caption of browser window"If Err = 0 Then SendKeys "^a^c"End If 1:2:3:4:5:
Expert: thenelson replied at 2024-07-31 06:09:25
This sample database will show you how to transfer information to and from the internet using: The Web Browser control, Internet Explorer Automation and FTP - File Transfer Protocol. It also contains many functions useful for interfacing with the internet. http://thenelson.name/#WebAccess
You should not need to use sendkeys. You should be able to copy the resultant page with
documentElement.Innerhtml
documentElement.Outerhtml
documentElement.Innertext
documentElement.OuterText
depending upon what you want to copy.
Expert: eenookami replied at 2024-07-31 04:37:40
canesbr,
A message has been sent to some additional experts asking them to review your question. We will check back again to see if you are getting the help you need.
Please do not respond to this comment; we will be monitoring your question for activity from the Experts.
Thank you for using Experts Exchange,
eenookami
CS Moderator
http://www.experts-exchange.com/R_32352.html
eenookami
CS Moderator
Author: canesbr replied at 2024-07-19 11:42:57
Yes the original post said a search for a particular web page. After copying, it will be pasted into a worksheet.
Regards
Brian
Regards
Brian
Expert: imnorie replied at 2024-07-19 10:51:59
Brian
What do you want to do with what you are copying from the browser window?
WIll the browser be showing a particulare page/site?
Expert: eenookami replied at 2024-07-19 07:11:53
canesbr,
eenookami
Community Support Moderator
eenookami
Expert: duncanb7 replied at 2024-07-14 10:24:24
I think other experts could help on this thread if you click "attention request' on this thread
Have a nice day , talk you tomorrow
Expert: duncanb7 replied at 2024-07-14 10:20:08
yes you are right, you need to add Public Declare Function SetForegroundWindow Lib "user32" (ByVal hwnd As Long) As Long
application.sendkeys will be okay, as I know from memory, I need to
do to setforeground at the sendkeys with object handler
anway, it is closer to solve all your issue
Be reminded, those code is for reference only you need to debug it
Author: canesbr replied at 2024-07-14 10:16:38
In the statement w.sendkeys, I get Run-time error '438': Object doesn't support the property or method.
If I use Application.sendkeys, the VBA code gets selected and copied.
Regards
Brian
Note: I added
Regards
Brian
Note: I added
Expert: duncanb7 replied at 2024-07-14 09:28:04
Dim HWNDSrc As Long
HWNDSrc = w.HWND
SetForegroundWindow HWNDSrc 'set the IE object on the foreground on the screen
w.Sendkeys("^a^c")
Try this
HWNDSrc = w.HWND
w.Sendkeys("^a^c")
Try this
Expert: duncanb7 replied at 2024-07-14 08:22:11
just w.Sendkeys("^a^c")
Author: canesbr replied at 2024-07-14 07:15:15
Aha.
I mentioned Chrome in the original post.
Ok, No problem
Just one thing - If I am going to do a sendkeys I need the found window to have the focus. How?
Regards
Brian
Ok, No problem
Regards
Brian
Expert: duncanb7 replied at 2024-07-14 07:07:11
Chrome/FF is NOT allowed for this method, only for IE on VBA.
You might make new thread for Chrome/FF
Author: canesbr replied at 2024-07-14 06:58:23
That compiles ok thanks
This addresses IE and HTML
How would I adjust for other browsers like Chrome?
Regards
Brian
Regards
Brian
Expert: duncanb7 replied at 2024-07-14 06:27:15
1- need to define Global w As SHDocVw.InternetExplorer on the top
2- On VBA editor, you need to add MS internet library for using SHDocVw.inernetExplorer library
just do, click atl+11 going to VBC editor -->tools->macro libarary(first item in tools)->select
and check two options, one is called "Microsoft Internet Control" and other is "Microsoft HTML Object Library"
Be remined, it is reference code only for your start to solve issue, you need to debug it
Global w As SHDocVw.InternetExplorerPublic Declare Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long)Function IEWindowFromTitle(sTitle As String) As SHDocVw.InternetExplorer Dim objShellWindows As New SHDocVw.ShellWindows Dim win As Object, rv As SHDocVw.InternetExplorer For Each win In objShellWindows If TypeName(win.Document) = "HTMLDocument" Then If UCase(win.Document.Title) = UCase(sTitle) Then Set rv = win Exit For End If End If Next Set IEWindowFromTitle = rvEnd FunctionSub Tester() Dim w As SHDocVw.InternetExplorer Set w = IEWindowFromTitle("Google") If Not w Is Nothing Then Debug.Print w.Document.Title Else Debug.Print "Not found" End IfEnd Sub 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:
Author: canesbr replied at 2024-07-14 05:50:46
I apologize for not understanding.
You posted some code.
I copied and pasted it into a module
I tried to run it and I got a compile error.
"User-defined type not defined."
Which to me means there is something wrong with the code.
What exactly is wrong with the code?
Regards
Brian
Regards
Brian
Expert: duncanb7 replied at 2024-07-13 16:14:05
When you open IE browser, it will show the title of that browser at the most top and right corner that is exactly same as the string in <title>Google</title> tag when the browser address bar is going to http://www.google.com and that will assist the VBA program to find out the browser object,For example, when IE go to www.google.com, the title tag is "Google" and then Set w = IEWindowFromTitle("Google") will find out the IE object, and stored it at w, when you try w.Sendkeys("^a^c"), it will send the key to IE object that belong to the tiltle with Google.
you can start code and run Tester() subroutine for a start to see any compiling error first
(Note: You can view the webpage source code from www.google.com
and search title tag that show the string of "Google")
Author: canesbr replied at 2024-07-13 11:54:12
I am not following you
Please identify compile error.
Regards
Brian
Regards
Brian
Expert: duncanb7 replied at 2024-07-13 09:43:20
Please work around the code is okay but not tested
And it will work after pass those typing error, at least give you
idea and have a good start
Author: canesbr replied at 2024-07-13 09:39:45
On the Function statement I get Compile Error User-defined type not defined.
REgards
Brian
REgards
Brian
Expert: duncanb7 replied at 2024-07-12 21:00:08
The following code is getting browser object from searching browser title that
is easier way to solve your question. You can modify the code for your need if search from URL(address bar)
Proabably, you can put w.Sendkeys("^a^c") for a try. It might be a good start to solve your
issue
issue
