When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Ravi Kalla
at 2024-07-11 11:10:17
Point:500 Replies:6 POST_ID:828956USER_ID:11856
Web Browsers;Hypertext Markup Language (HTML);Hypertext Transfer Protocol (HTTP)
My Internet Explorer is not sending below line in the header-
I confirmed this by checking the response content type in IE DeveloperTools. "TEXT/HTML" is appearing there in "Type" field.
FireFox browser, is sending GZIP in the header and getting the compressed response.
How can I enable GZIP for IE?
Author: Ravi Kalla replied at 2024-07-22 02:16:58
Though my own solution is perfect fit for my need, "duncanb7" has provided some good links and answer.
Expert: duncanb7 replied at 2024-07-17 07:46:52
Author: Ravi Kalla replied at 2024-07-17 07:41:51
I found that IE is sending "Accept-Encoding: gzip, deflate" in the request header with the help of -
DeveloperTools->Network->StartCapturing->Select a request and click "Go to detailed view"->Request headers
I confused earlier as the Response header doesn't contain "Content-Encoding : gzip" in it even though GZIP coming to the IE browser. Reason for this is-
IE decodes(or decompresses) the response even before pushing the header to DeveloperTools. So, it is not shown as compressed content in the response header. Where as in FireFox, RAW response is shown in the FireBug where in we can see “Content-Encoding : gzip” in the response header and then uncompression is done.
Reference link.
Reference link.
Expert: duncanb7 replied at 2024-07-11 16:41:36
Could you use Fiddler or Charles http debugger as following links to view the request and response instead of using IE developer tools ?
http://www.techspot.com/downloads/5461-fiddler.html
http://www.charlesproxy.com/
Probably you can view Accept-Encoding:gzip. The issue may be
due to inspect process from IE developer tools
Similar issue for Content-encoding happen before from this link
due to IE developer tools ( article date in 2012)
http://blogs.msdn.com/b/kaushal/archive/2012/07/23/i-don-t-see-content-encoding-header-in-ie-http-debugger-f12-developer-tools.aspx
Have you received compressed raw data or decompressed file data completely from both IE and FF regardless of Accept-encoding issue on IE developer tools ?
Author: Ravi Kalla replied at 2024-07-11 14:32:09
It is HTTP link. As it is intranet site, exact link may not be useful. I enabled gzip on the server side and it is working for FireFox browser.
gzip is not working for IE browser only as it is not sending Accept-Encoding: gzip, deflate in its header.
And yes "Do not save encrypted pages to a disk" check box is not selected.
Expert: duncanb7 replied at 2024-07-11 11:33:43
The link is http or https ?
Is it okay let us know the exact link site path so that we can try it at our side with Charles http proxy debugger
Could you try this follows to see any improvement ?
-1 On the Tools menu in Internet Explorer, click Internet Options.
-2 Click the Advanced tab.
-3 In the Settings box, scroll down to the Security section, and then make sure that the Do not save encrypted pages to a disk check box is not selected.
Hope understand your question completely.If not, please point it out.
